[GRASS-QA] GRASS QA: glynn |
./grass6/imagery/i.ortho.photo/photo.elev/main.c |no clones |
0 monsters | 0 warnings
grass-qa at proxy.soccerlab.polymtl.ca
Sun Apr 15 17:07:52 EDT 2007
Hello glynn,
ANALYSIS
imagery/i.ortho.photo/photo.elev/main.c functions
main (Begins at: 22 Ends at: 103)
Complexity: | 5 | | OK |
ParamNBR: | 2 | | OK |
CalledNBR: | 39 | * | |
LOC: | 82 | | OK |
metrics are OK
select_current_env (Begins at: 105 Ends at: 115)
Complexity: | 2 | | OK |
ParamNBR: | 1 | | OK |
CalledNBR: | 2 | | OK |
LOC: | 11 | | OK |
metrics are OK
select_target_env (Begins at: 117 Ends at: 127)
LOC: | 11 | | OK |
metrics are OK
Clone analysis:
This file does not contain cloned functions
Threshold GRASS6 key metrics values at 2007-04-15 are:
median | upper | outlier |
| quartile | limit |
Complexity (Cyclo): 5 | 25 | 37 |
ParamNBR: 2 | 6 | 9 |
CalledNBR: 10 | 60 | 87 |
LOC: 43 | 195 | 272 |
LOC: Lines Of Code
Message interpretation:
OK : Nothing to say at all
* : above 75 % of value warning
Brought to you by:
