[GRASS-QA] GRASS QA: glynn | ./grass6/lib/vector/diglib/cindex_rw.c |no clones | 0 monsters | 0 warnings
Sun Apr 15 17:07:52 EDT 2007
Hello glynn,
ANALYSIS
lib/vector/diglib/cindex_rw.c functions
dig_write_cidx_head (Begins at: 22 Ends at: 90)
Complexity:   |      11 |       |      OK |
CalledNBR:    |      19 |       |      OK |
LOC:          |      69 |       |      OK |
metrics are OK
dig_read_cidx_head (Begins at: 94 Ends at: 186)
Complexity:   |      14 |       |      OK |
CalledNBR:    |      21 |       |      OK |
LOC:          |      93 |       |      OK |
metrics are OK
dig_write_cidx (Begins at: 190 Ends at: 221)
Complexity:   |       2 |       |      OK |
CalledNBR:    |       8 |       |      OK |
LOC:          |      32 |       |      OK |
metrics are OK
dig_read_cidx (Begins at: 228 Ends at: 271)
Complexity:   |       5 |       |      OK |
ParamNBR:     |       3 |       |      OK |
CalledNBR:    |      10 |       |      OK |
LOC:          |      44 |       |      OK |
metrics are OK
Clone analysis:
Threshold GRASS6 key metrics values at 2007-04-15 are:
                           | quartile  | limit   |
ParamNBR:                2 |         6 |       9 |
CalledNBR:              10 |        60 |      87 |
LOC:                    43 |       195 |     272 |
 LOC: Lines Of Code
Message interpretation:
 OK : Nothing to say at all
Brought to you by:
