[GRASS-QA] GRASS QA: glynn | ./grass6/raster/simwe/simlib/output.c |no clones | 3 monsters | 0 warnings
Sun Apr 15 17:07:55 EDT 2007
Hello glynn,
ANALYSIS
raster/simwe/simlib/output.c functions
output_data (Begins at: 14 Ends at: 559)
Complexity:   |      77 |   *** | MONSTER |
CalledNBR:    |     189 |   *** | MONSTER |
LOC:          |     546 |   *** | MONSTER |
3 metric are OUT OF RANGE!
output_et (Begins at: 562 Ends at: 709)
Complexity:   |      17 |     * |         |
ParamNBR:     |       0 |       |      OK |
CalledNBR:    |      36 |     * |         |
LOC:          |     148 |     * |         |
metrics are OK
Clone analysis:
Threshold GRASS6 key metrics values at 2007-04-15 are:
                           | quartile  | limit   |
ParamNBR:                2 |         6 |       9 |
CalledNBR:              10 |        60 |      87 |
LOC:                    43 |       195 |     272 |
 LOC: Lines Of Code
Message interpretation:
 OK : Nothing to say at all
Brought to you by:
