[GRASS-QA] GRASS QA: glynn | ./grass6/imagery/i.points/input.c |5
clones ( ask.c ask_mag.c cell.c digit.c input.c )| 0 monsters
| 0 warnings
grass-qa at proxy.soccerlab.polymtl.ca
Sun Apr 15 17:35:29 EDT 2007
Hello glynn,
ANALYSIS
imagery/i.points/input.c functions
Input_pointer (Begins at: 20 Ends at: 23)
Complexity: | 1 | | OK |
ParamNBR: | 1 | | OK |
CalledNBR: | 1 | | OK |
LOC: | 4 | | OK |
metrics are OK
Input_box (Begins at: 25 Ends at: 28)
ParamNBR: | 3 | | OK |
LOC: | 4 | | OK |
metrics are OK
Input_other (Begins at: 30 Ends at: 46)
Complexity: | 2 | | OK |
ParamNBR: | 2 | | OK |
CalledNBR: | 5 | | OK |
LOC: | 17 | | OK |
metrics are OK
mouse (Begins at: 48 Ends at: 103)
Complexity: | 12 | | OK |
ParamNBR: | 4 | | OK |
CalledNBR: | 9 | | OK |
LOC: | 56 | | OK |
metrics are OK
use_mouse_msg (Begins at: 107 Ends at: 112)
LOC: | 6 | | OK |
metrics are OK
draw_objects (Begins at: 114 Ends at: 178)
Complexity: | 8 | | OK |
CalledNBR: | 16 | | OK |
LOC: | 65 | | OK |
metrics are OK
find (Begins at: 180 Ends at: 202)
Complexity: | 7 | | OK |
LOC: | 23 | | OK |
metrics are OK
select_option (Begins at: 204 Ends at: 216)
Complexity: | 3 | | OK |
CalledNBR: | 0 | | OK |
LOC: | 13 | | OK |
metrics are OK
draw_option_boxes (Begins at: 218 Ends at: 237)
LOC: | 20 | | OK |
metrics are OK
visible (Begins at: 239 Ends at: 244)
LOC: | 6 | | OK |
metrics are OK
Menu_msg (Begins at: 246 Ends at: 266)
LOC: | 21 | | OK |
metrics are OK
Start_mouse_in_menu (Begins at: 269 Ends at: 276)
LOC: | 8 | | OK |
metrics are OK
Clone analysis:
This file has 5 potentially cloned functions:
mouse select_option find draw_option_boxes draw_objects
In imagery/i.points/input.c clones of select_option are:
imagery/i.vpoints/input.c select_option
imagery/i.ortho.photo/photo.2target/input.c select_option
imagery/i.ortho.photo/photo.2image/input.c select_option
imagery/i.class/input.c select_option
In imagery/i.points/input.c clones of mouse are:
imagery/i.class/input.c mouse
In imagery/i.points/input.c clones of draw_option_boxes are:
imagery/i.vpoints/input.c draw_option_boxes
In imagery/i.points/input.c clones of draw_objects are:
imagery/i.vpoints/input.c draw_objects
imagery/i.ortho.photo/photo.2target/input.c draw_objects
imagery/i.ortho.photo/photo.2image/input.c draw_objects
imagery/i.class/input.c draw_objects
In imagery/i.points/input.c clones of find are:
imagery/i.vpoints/input.c find
imagery/i.ortho.photo/photo.2target/input.c find
imagery/i.ortho.photo/photo.2image/input.c find
imagery/i.class/input.c find
Threshold GRASS6 key metrics values at 2007-04-15 are:
median | upper | outlier |
| quartile | limit |
Complexity (Cyclo): 5 | 25 | 37 |
ParamNBR: 2 | 6 | 9 |
CalledNBR: 10 | 60 | 87 |
LOC: 43 | 195 | 272 |
LOC: Lines Of Code
Message interpretation:
OK : Nothing to say at all
* : above 75 % of value warning
Brought to you by:
