[GRASS-QA] GRASS QA: glynn | ./grass6/raster/r.walk/memory.c |no clones | 0 monsters | 0 warnings
Sun Apr 15 17:35:31 EDT 2007
Hello glynn,
ANALYSIS
raster/r.walk/memory.c functions
allocate (Begins at: 36 Ends at: 77)
Complexity:   |       4 |       |      OK |
ParamNBR:     |       1 |       |      OK |
CalledNBR:    |       5 |       |      OK |
LOC:          |      42 |       |      OK |
metrics are OK
release (Begins at: 82 Ends at: 98)
Complexity:   |       3 |       |      OK |
CalledNBR:    |       1 |       |      OK |
LOC:          |      17 |       |      OK |
metrics are OK
get (Begins at: 103 Ends at: 116)
CalledNBR:    |       2 |       |      OK |
LOC:          |      14 |       |      OK |
metrics are OK
give (Begins at: 121 Ends at: 131)
Complexity:   |       2 |       |      OK |
CalledNBR:    |       0 |       |      OK |
LOC:          |      11 |       |      OK |
metrics are OK
Clone analysis:
Threshold GRASS6 key metrics values at 2007-04-15 are:
                           | quartile  | limit   |
ParamNBR:                2 |         6 |       9 |
CalledNBR:              10 |        60 |      87 |
LOC:                    43 |       195 |     272 |
 LOC: Lines Of Code
Message interpretation:
 OK : Nothing to say at all
Brought to you by:
