[GRASS-QA] GRASS QA: glynn | ./grass6/imagery/i.ifft/orig_wind.c |2
clones ( orig_wind.c )| 0 monsters | 0 warnings
grass-qa at proxy.soccerlab.polymtl.ca
Sun Apr 15 23:22:19 EDT 2007
Hello glynn,
ANALYSIS
imagery/i.ifft/orig_wind.c functions
get_orig_window (Begins at: 9 Ends at: 32)
Complexity: | 2 | | OK |
ParamNBR: | 3 | | OK |
CalledNBR: | 6 | | OK |
LOC: | 24 | | OK |
metrics are OK
Clone analysis:
This file has 2 potentially cloned functions:
put_orig_window get_orig_window
In imagery/i.ifft/orig_wind.c clones of get_orig_window are:
imagery/i.fft/orig_wind.c get_orig_window
In imagery/i.ifft/orig_wind.c clones of put_orig_window are:
imagery/i.fft/orig_wind.c put_orig_window
Threshold GRASS6 key metrics values at 2007-04-15 are:
median | upper | outlier |
| quartile | limit |
Complexity (Cyclo): 5 | 25 | 37 |
ParamNBR: 2 | 6 | 9 |
CalledNBR: 10 | 60 | 87 |
LOC: 43 | 195 | 272 |
LOC: Lines Of Code
Message interpretation:
OK : Nothing to say at all
* : above 75 % of value warning
Brought to you by:
