[GRASS-QA] GRASS QA: glynn | ./grass6/lib/gis/histogram.c |no
clones | 0 monsters | 0 warnings
grass-qa at proxy.soccerlab.polymtl.ca
Sun Apr 15 23:22:20 EDT 2007
Hello glynn,
ANALYSIS
lib/gis/histogram.c functions
G_init_histogram (Begins at: 22 Ends at: 45)
Complexity: | 1 | | OK |
ParamNBR: | 1 | | OK |
CalledNBR: | 0 | | OK |
LOC: | 24 | | OK |
metrics are OK
G_read_histogram (Begins at: 47 Ends at: 108)
Complexity: | 6 | | OK |
ParamNBR: | 3 | | OK |
CalledNBR: | 18 | | OK |
LOC: | 62 | | OK |
metrics are OK
G_write_histogram (Begins at: 110 Ends at: 141)
Complexity: | 3 | | OK |
ParamNBR: | 2 | | OK |
CalledNBR: | 3 | | OK |
LOC: | 32 | | OK |
metrics are OK
G_write_histogram_cs (Begins at: 143 Ends at: 172)
Complexity: | 4 | | OK |
CalledNBR: | 5 | | OK |
LOC: | 30 | | OK |
metrics are OK
G_make_histogram_cs (Begins at: 174 Ends at: 199)
Complexity: | 2 | | OK |
LOC: | 26 | | OK |
metrics are OK
G_get_histogram_num (Begins at: 201 Ends at: 212)
LOC: | 12 | | OK |
metrics are OK
G_get_histogram_cat (Begins at: 214 Ends at: 229)
LOC: | 16 | | OK |
metrics are OK
G_get_histogram_count (Begins at: 231 Ends at: 245)
LOC: | 15 | | OK |
metrics are OK
G_free_histogram (Begins at: 247 Ends at: 264)
CalledNBR: | 1 | | OK |
LOC: | 18 | | OK |
metrics are OK
G_sort_histogram (Begins at: 266 Ends at: 303)
Complexity: | 5 | | OK |
LOC: | 38 | | OK |
metrics are OK
cmp (Begins at: 306 Ends at: 326)
LOC: | 21 | | OK |
metrics are OK
G_sort_histogram_by_count (Begins at: 328 Ends at: 342)
LOC: | 15 | | OK |
metrics are OK
cmp_count (Begins at: 345 Ends at: 362)
LOC: | 18 | | OK |
metrics are OK
fopen_histogram_new (Begins at: 364 Ends at: 382)
CalledNBR: | 4 | | OK |
LOC: | 19 | | OK |
metrics are OK
G_remove_histogram (Begins at: 384 Ends at: 401)
LOC: | 18 | | OK |
metrics are OK
G_add_histogram (Begins at: 403 Ends at: 432)
LOC: | 30 | | OK |
metrics are OK
G_set_histogram (Begins at: 434 Ends at: 461)
LOC: | 28 | | OK |
metrics are OK
G_extend_histogram (Begins at: 463 Ends at: 482)
LOC: | 20 | | OK |
metrics are OK
G_zero_histogram (Begins at: 484 Ends at: 492)
LOC: | 9 | | OK |
metrics are OK
Clone analysis:
This file does not contain cloned functions
Threshold GRASS6 key metrics values at 2007-04-15 are:
median | upper | outlier |
| quartile | limit |
Complexity (Cyclo): 5 | 25 | 37 |
ParamNBR: 2 | 6 | 9 |
CalledNBR: 10 | 60 | 87 |
LOC: 43 | 195 | 272 |
LOC: Lines Of Code
Message interpretation:
OK : Nothing to say at all
* : above 75 % of value warning
Brought to you by:
