[GRASS-QA] GRASS QA: martinl | ./grass6/vector/v.edit/a2b.c |1
clones ( a2b.c )| 0 monsters | 1 warnings
grass-qa at proxy.soccerlab.polymtl.ca
Mon Apr 16 05:00:58 EDT 2007
Hello martinl,
ANALYSIS
vector/v.edit/a2b.c functions
asc_to_bin (Begins at: 10 Ends at: 175)
Complexity: | 29 | ** | Warning |
ParamNBR: | 2 | | OK |
CalledNBR: | 42 | * | |
LOC: | 166 | * | |
at least 1 values are close to an outlier please consider revising code
read_head (Begins at: 178 Ends at: 227)
Complexity: | 18 | * | |
CalledNBR: | 33 | | OK |
LOC: | 50 | | OK |
metrics are OK
Clone analysis:
This file has 1 potentially cloned functions:
read_head
In vector/v.edit/a2b.c clones of read_head are:
vector/v.in.ascii/head.c read_head
Threshold GRASS6 key metrics values at 2007-04-16 are:
median | upper | outlier |
| quartile | limit |
Complexity (Cyclo): 5 | 25 | 37 |
ParamNBR: 2 | 6 | 9 |
CalledNBR: 10 | 60 | 87 |
LOC: 43 | 195 | 272 |
LOC: Lines Of Code
Message interpretation:
OK : Nothing to say at all
* : above 75 % of value warning
Brought to you by:
