[GRASS-QA] GRASS QA: martinl | ./grass6/vector/v.edit/vertex.c |no clones | 0 monsters | 0 warnings
Mon Apr 16 05:00:59 EDT 2007
Hello martinl,
ANALYSIS
vector/v.edit/vertex.c functions
do_move_vertex (Begins at: 23 Ends at: 145)
Complexity:   |      11 |       |      OK |
ParamNBR:     |       1 |       |      OK |
CalledNBR:    |      28 |       |      OK |
LOC:          |     123 |     * |         |
metrics are OK
do_break (Begins at: 147 Ends at: 223)
Complexity:   |       5 |       |      OK |
CalledNBR:    |      23 |       |      OK |
LOC:          |      77 |       |      OK |
metrics are OK
do_remove_vertex (Begins at: 225 Ends at: 292)
Complexity:   |       7 |       |      OK |
CalledNBR:    |      24 |       |      OK |
LOC:          |      68 |       |      OK |
metrics are OK
do_split (Begins at: 294 Ends at: 372)
Complexity:   |       6 |       |      OK |
LOC:          |      79 |       |      OK |
metrics are OK
Clone analysis:
Threshold GRASS6 key metrics values at 2007-04-16 are:
                           | quartile  | limit   |
ParamNBR:                2 |         6 |       9 |
CalledNBR:              10 |        60 |      87 |
LOC:                    43 |       195 |     272 |
 LOC: Lines Of Code
Message interpretation:
 OK : Nothing to say at all
Brought to you by:
