[GRASS-QA] GRASS QA: martinl | ./grass6/vector/v.edit/select.c |no clones | 0 monsters | 0 warnings
Mon Apr 16 05:00:59 EDT 2007
Hello martinl,
ANALYSIS
vector/v.edit/select.c functions
select_lines (Begins at: 24 Ends at: 66)
Complexity:   |       7 |       |      OK |
ParamNBR:     |       1 |       |      OK |
CalledNBR:    |      10 |       |      OK |
LOC:          |      43 |       |      OK |
metrics are OK
do_print_selected (Begins at: 74 Ends at: 90)
Complexity:   |       1 |       |      OK |
CalledNBR:    |       3 |       |      OK |
LOC:          |      17 |       |      OK |
metrics are OK
sel_by_cat (Begins at: 97 Ends at: 146)
Complexity:   |       4 |       |      OK |
ParamNBR:     |       3 |       |      OK |
CalledNBR:    |      12 |       |      OK |
LOC:          |      50 |       |      OK |
metrics are OK
sel_by_coordinates (Begins at: 153 Ends at: 205)
CalledNBR:    |      13 |       |      OK |
LOC:          |      53 |       |      OK |
metrics are OK
sel_by_bbox (Begins at: 212 Ends at: 255)
Complexity:   |       3 |       |      OK |
LOC:          |      44 |       |      OK |
metrics are OK
sel_by_polygon (Begins at: 262 Ends at: 310)
CalledNBR:    |      15 |       |      OK |
LOC:          |      49 |       |      OK |
metrics are OK
sel_by_id (Begins at: 317 Ends at: 360)
CalledNBR:    |       9 |       |      OK |
LOC:          |      44 |       |      OK |
metrics are OK
sel_by_where (Begins at: 367 Ends at: 440)
Complexity:   |       8 |       |      OK |
CalledNBR:    |      26 |       |      OK |
LOC:          |      74 |       |      OK |
metrics are OK
merge_lists (Begins at: 442 Ends at: 460)
Complexity:   |       2 |       |      OK |
CalledNBR:    |       5 |       |      OK |
LOC:          |      19 |       |      OK |
metrics are OK
Clone analysis:
Threshold GRASS6 key metrics values at 2007-04-16 are:
                           | quartile  | limit   |
ParamNBR:                2 |         6 |       9 |
CalledNBR:              10 |        60 |      87 |
LOC:                    43 |       195 |     272 |
 LOC: Lines Of Code
Message interpretation:
 OK : Nothing to say at all
Brought to you by:
