[GRASS-QA] GRASS QA: martinl | ./grass6/vector/v.edit/move.c |no clones | 0 monsters | 0 warnings
Mon Apr 16 05:06:15 EDT 2007
Hello martinl,
ANALYSIS
vector/v.edit/move.c functions
do_move (Begins at: 23 Ends at: 81)
Complexity:   |       3 |       |      OK |
ParamNBR:     |       1 |       |      OK |
CalledNBR:    |      15 |       |      OK |
LOC:          |      59 |       |      OK |
metrics are OK
Clone analysis:
Threshold GRASS6 key metrics values at 2007-04-16 are:
                           | quartile  | limit   |
ParamNBR:                2 |         6 |       9 |
CalledNBR:              10 |        60 |      87 |
LOC:                    43 |       195 |     272 |
 LOC: Lines Of Code
Message interpretation:
 OK : Nothing to say at all
Brought to you by:
