[GRASS-QA] GRASS QA: glynn | ./grass6/raster/r.fill.dir/resolve.c
|2 clones ( write.c write.c resolve.c tinf.c resolve.c )| 0
monsters | 1 warnings
grass-qa at proxy.soccerlab.polymtl.ca
Mon Apr 16 16:44:20 EDT 2007
Hello glynn,
ANALYSIS
raster/r.fill.dir/resolve.c functions
select_dir (Begins at: 7 Ends at: 31)
Complexity: | 1 | | OK |
ParamNBR: | 1 | | OK |
CalledNBR: | 0 | | OK |
LOC: | 25 | | OK |
metrics are OK
flink (Begins at: 33 Ends at: 89)
Complexity: | 12 | | OK |
ParamNBR: | 9 | *** | MONSTER |
CalledNBR: | 2 | | OK |
LOC: | 57 | | OK |
at least 1 values are close to an outlier please consider revising code
resolve (Begins at: 91 Ends at: 209)
ParamNBR: | 3 | | OK |
CalledNBR: | 30 | | OK |
LOC: | 119 | | OK |
metrics are OK
Clone analysis:
This file has 2 potentially cloned functions:
flink select_dir
In raster/r.fill.dir/resolve.c clones of select_dir are:
raster/r.drain/resolve.c select_dir
In raster/r.fill.dir/resolve.c clones of flink are:
raster/r.drain/resolve.c flink
Threshold GRASS6 key metrics values at 2007-04-16 are:
median | upper | outlier |
| quartile | limit |
Complexity (Cyclo): 5 | 25 | 37 |
ParamNBR: 2 | 6 | 9 |
CalledNBR: 10 | 60 | 87 |
LOC: 43 | 195 | 272 |
LOC: Lines Of Code
Message interpretation:
OK : Nothing to say at all
* : above 75 % of value warning
Brought to you by:
