[GRASS-QA] GRASS QA: glynn | ./grass6/raster/r.support/modhead/ask_format.c |no clones | 0 monsters | 0 warnings
Mon Apr 16 16:44:20 EDT 2007
Hello glynn,
ANALYSIS
raster/r.support/modhead/ask_format.c functions
ask_format (Begins at: 14 Ends at: 80)
Complexity:   |      10 |       |      OK |
ParamNBR:     |       3 |       |      OK |
CalledNBR:    |      31 |       |      OK |
LOC:          |      67 |       |      OK |
metrics are OK
Clone analysis:
Threshold GRASS6 key metrics values at 2007-04-16 are:
                           | quartile  | limit   |
ParamNBR:                2 |         6 |       9 |
CalledNBR:              10 |        60 |      87 |
LOC:                    43 |       195 |     272 |
 LOC: Lines Of Code
Message interpretation:
 OK : Nothing to say at all
Brought to you by:
