[GRASS-QA] GRASS QA: markus | ./grass6/vector/lidar/lidarlib/zones.c |no clones | 0 monsters | 0 warnings
Mon Apr 16 17:48:29 EDT 2007
Hello markus,
ANALYSIS
vector/lidar/lidarlib/zones.c functions
P_zero_dim (Begins at: 15 Ends at: 22)
Complexity:   |       1 |       |      OK |
ParamNBR:     |       1 |       |      OK |
CalledNBR:    |       0 |       |      OK |
LOC:          |       8 |       |      OK |
metrics are OK
P_set_regions (Begins at: 26 Ends at: 85)
Complexity:   |       8 |       |      OK |
ParamNBR:     |       5 |     * |         |
CalledNBR:    |       1 |       |      OK |
LOC:          |      60 |       |      OK |
metrics are OK
P_get_orlo (Begins at: 89 Ends at: 103)
Complexity:   |       3 |       |      OK |
ParamNBR:     |       4 |       |      OK |
LOC:          |      15 |       |      OK |
metrics are OK
P_get_BandWidth (Begins at: 107 Ends at: 116)
Complexity:   |       2 |       |      OK |
LOC:          |      10 |       |      OK |
metrics are OK
P_Mean_Calc (Begins at: 120 Ends at: 143)
ParamNBR:     |       3 |       |      OK |
CalledNBR:    |       2 |       |      OK |
LOC:          |      24 |       |      OK |
metrics are OK
P_Read_Vector_Region_Map (Begins at: 147 Ends at: 200)
Complexity:   |       5 |       |      OK |
CalledNBR:    |      11 |       |      OK |
LOC:          |      54 |       |      OK |
metrics are OK
P_Create_Aux_Table (Begins at: 204 Ends at: 229)
CalledNBR:    |      14 |       |      OK |
LOC:          |      26 |       |      OK |
metrics are OK
P_Drop_Aux_Table (Begins at: 232 Ends at: 239)
CalledNBR:    |       4 |       |      OK |
LOC:          |       8 |       |      OK |
metrics are OK
P_Aux_to_Raster (Begins at: 242 Ends at: 264)
LOC:          |      23 |       |      OK |
metrics are OK
P_Aux_to_Vector (Begins at: 268 Ends at: 323)
Complexity:   |       4 |       |      OK |
CalledNBR:    |      21 |       |      OK |
LOC:          |      56 |       |      OK |
metrics are OK
Clone analysis:
Threshold GRASS6 key metrics values at 2007-04-16 are:
                           | quartile  | limit   |
ParamNBR:                2 |         6 |       9 |
CalledNBR:              10 |        60 |      87 |
LOC:                    43 |       195 |     272 |
 LOC: Lines Of Code
Message interpretation:
 OK : Nothing to say at all
Brought to you by:
