[GRASS-QA] GRASS QA: soeren | ./grass6/lib/gpde/N_gradient_calc.c
|no clones | 0 monsters | 0 warnings
grass-qa at proxy.soccerlab.polymtl.ca
Mon Apr 16 19:36:06 EDT 2007
Hello soeren,
ANALYSIS
lib/gpde/N_gradient_calc.c functions
N_calc_gradient_field_2d_stats (Begins at: 29 Ends at: 102)
Complexity: | 3 | | OK |
ParamNBR: | 1 | | OK |
CalledNBR: | 3 | | OK |
LOC: | 74 | | OK |
metrics are OK
N_compute_gradient_field_2d (Begins at: 104 Ends at: 239)
Complexity: | 10 | | OK |
ParamNBR: | 5 | * | |
CalledNBR: | 27 | | OK |
LOC: | 136 | * | |
metrics are OK
N_compute_gradient_field_components_2d (Begins at: 242 Ends at: 287)
Complexity: | 5 | | OK |
ParamNBR: | 3 | | OK |
CalledNBR: | 7 | | OK |
LOC: | 46 | | OK |
metrics are OK
N_calc_gradient_field_3d_stats (Begins at: 289 Ends at: 372)
Complexity: | 7 | | OK |
CalledNBR: | 4 | | OK |
LOC: | 84 | | OK |
metrics are OK
N_compute_gradient_field_3d (Begins at: 374 Ends at: 564)
Complexity: | 13 | | OK |
ParamNBR: | 6 | * | |
CalledNBR: | 41 | * | |
LOC: | 191 | * | |
metrics are OK
N_compute_gradient_field_components_3d (Begins at: 567 Ends at: 616)
ParamNBR: | 4 | | OK |
CalledNBR: | 10 | | OK |
LOC: | 50 | | OK |
metrics are OK
Clone analysis:
This file does not contain cloned functions
Threshold GRASS6 key metrics values at 2007-04-16 are:
median | upper | outlier |
| quartile | limit |
Complexity (Cyclo): 5 | 25 | 37 |
ParamNBR: 2 | 6 | 9 |
CalledNBR: 10 | 60 | 87 |
LOC: 43 | 195 | 272 |
LOC: Lines Of Code
Message interpretation:
OK : Nothing to say at all
* : above 75 % of value warning
Brought to you by:
