[GRASS-QA] GRASS QA: soeren | ./grass6/lib/gpde/N_arrays.c |4
clones ( N_arrays.c )| 0 monsters | 0 warnings
grass-qa at proxy.soccerlab.polymtl.ca
Mon Apr 16 19:36:06 EDT 2007
Hello soeren,
ANALYSIS
lib/gpde/N_arrays.c functions
N_alloc_array_2d (Begins at: 69 Ends at: 119)
Complexity: | 6 | | OK |
ParamNBR: | 4 | | OK |
CalledNBR: | 9 | | OK |
LOC: | 51 | | OK |
metrics are OK
N_free_array_2d (Begins at: 127 Ends at: 159)
Complexity: | 5 | | OK |
ParamNBR: | 1 | | OK |
CalledNBR: | 5 | | OK |
LOC: | 33 | | OK |
metrics are OK
N_get_array_2d_type (Begins at: 161 Ends at: 176)
Complexity: | 1 | | OK |
CalledNBR: | 0 | | OK |
LOC: | 16 | | OK |
metrics are OK
N_get_array_2d_value (Begins at: 179 Ends at: 226)
Complexity: | 8 | | OK |
LOC: | 48 | | OK |
metrics are OK
N_is_array_2d_value_null (Begins at: 228 Ends at: 309)
ParamNBR: | 3 | | OK |
CalledNBR: | 12 | | OK |
LOC: | 82 | | OK |
metrics are OK
N_get_array_2d_c_value (Begins at: 311 Ends at: 341)
CalledNBR: | 3 | | OK |
LOC: | 31 | | OK |
metrics are OK
N_get_array_2d_f_value (Begins at: 343 Ends at: 373)
LOC: | 31 | | OK |
metrics are OK
N_get_array_2d_d_value (Begins at: 375 Ends at: 406)
LOC: | 32 | | OK |
metrics are OK
N_put_array_2d_value (Begins at: 409 Ends at: 453)
CalledNBR: | 1 | | OK |
LOC: | 45 | | OK |
metrics are OK
N_put_array_2d_value_null (Begins at: 455 Ends at: 517)
CalledNBR: | 7 | | OK |
LOC: | 63 | | OK |
metrics are OK
N_put_array_2d_c_value (Begins at: 520 Ends at: 548)
Complexity: | 4 | | OK |
LOC: | 29 | | OK |
metrics are OK
N_put_array_2d_f_value (Begins at: 551 Ends at: 579)
LOC: | 29 | | OK |
metrics are OK
N_put_array_2d_d_value (Begins at: 582 Ends at: 601)
LOC: | 20 | | OK |
metrics are OK
N_print_array_2d_info (Begins at: 609 Ends at: 633)
CalledNBR: | 10 | | OK |
LOC: | 25 | | OK |
metrics are OK
N_print_array_2d (Begins at: 635 Ends at: 722)
LOC: | 88 | | OK |
metrics are OK
N_alloc_array_3d (Begins at: 724 Ends at: 769)
ParamNBR: | 5 | * | |
LOC: | 46 | | OK |
metrics are OK
N_free_array_3d (Begins at: 777 Ends at: 804)
CalledNBR: | 4 | | OK |
LOC: | 28 | | OK |
metrics are OK
N_get_array_3d_type (Begins at: 806 Ends at: 823)
LOC: | 18 | | OK |
metrics are OK
N_get_array_3d_value (Begins at: 826 Ends at: 876)
LOC: | 51 | | OK |
metrics are OK
N_is_array_3d_value_null (Begins at: 879 Ends at: 959)
CalledNBR: | 8 | | OK |
LOC: | 81 | | OK |
metrics are OK
N_get_array_3d_f_value (Begins at: 962 Ends at: 989)
CalledNBR: | 2 | | OK |
LOC: | 28 | | OK |
metrics are OK
N_get_array_3d_d_value (Begins at: 992 Ends at: 1020)
LOC: | 29 | | OK |
metrics are OK
N_put_array_3d_value (Begins at: 1023 Ends at: 1074)
LOC: | 52 | | OK |
metrics are OK
N_put_array_3d_value_null (Begins at: 1077 Ends at: 1144)
LOC: | 68 | | OK |
metrics are OK
N_put_array_3d_f_value (Begins at: 1147 Ends at: 1170)
Complexity: | 2 | | OK |
LOC: | 24 | | OK |
metrics are OK
N_put_array_3d_d_value (Begins at: 1173 Ends at: 1186)
LOC: | 14 | | OK |
metrics are OK
N_print_array_3d_info (Begins at: 1194 Ends at: 1218)
CalledNBR: | 11 | | OK |
LOC: | 25 | | OK |
metrics are OK
N_print_array_3d (Begins at: 1220 Ends at: 1241)
Complexity: | 3 | | OK |
LOC: | 22 | | OK |
metrics are OK
Clone analysis:
This file has 4 potentially cloned functions:
N_get_array_2d_f_value N_get_array_2d_c_value N_put_array_2d_f_value N_put_array_2d_c_value
In lib/gpde/N_arrays.c clones of N_put_array_2d_c_value are:
lib/gpde/N_arrays.c N_put_array_2d_f_value
In lib/gpde/N_arrays.c clones of N_put_array_2d_f_value are:
lib/gpde/N_arrays.c N_put_array_2d_c_value
In lib/gpde/N_arrays.c clones of N_get_array_2d_c_value are:
lib/gpde/N_arrays.c N_get_array_2d_f_value
In lib/gpde/N_arrays.c clones of N_get_array_2d_f_value are:
lib/gpde/N_arrays.c N_get_array_2d_c_value
Threshold GRASS6 key metrics values at 2007-04-16 are:
median | upper | outlier |
| quartile | limit |
Complexity (Cyclo): 5 | 25 | 37 |
ParamNBR: 2 | 6 | 9 |
CalledNBR: 10 | 60 | 87 |
LOC: 43 | 195 | 272 |
LOC: Lines Of Code
Message interpretation:
OK : Nothing to say at all
* : above 75 % of value warning
Brought to you by:
