[GRASS-QA] GRASS QA: glynn | ./grass6/lib/imagery/points.c |1
clones ( ask_group.c georef.c points.c )| 0 monsters | 0 warnings
grass-qa at proxy.soccerlab.polymtl.ca
Mon Apr 16 22:55:49 EDT 2007
Hello glynn,
ANALYSIS
lib/imagery/points.c functions
I_read_control_points (Begins at: 5 Ends at: 56)
Complexity: | 4 | | OK |
ParamNBR: | 2 | | OK |
CalledNBR: | 4 | | OK |
LOC: | 52 | | OK |
metrics are OK
I_new_control_point (Begins at: 58 Ends at: 81)
Complexity: | 2 | | OK |
ParamNBR: | 6 | * | |
CalledNBR: | 5 | | OK |
LOC: | 24 | | OK |
metrics are OK
I_write_control_points (Begins at: 83 Ends at: 111)
LOC: | 29 | | OK |
metrics are OK
I_get_control_points (Begins at: 113 Ends at: 154)
Complexity: | 3 | | OK |
CalledNBR: | 9 | | OK |
LOC: | 42 | | OK |
metrics are OK
I_put_control_points (Begins at: 156 Ends at: 175)
CalledNBR: | 6 | | OK |
LOC: | 20 | | OK |
metrics are OK
Clone analysis:
This file has 1 potentially cloned functions:
I_new_control_point
In lib/imagery/points.c clones of I_new_control_point are:
imagery/i.ortho.photo/libes/ref_points.c I_new_ref_point
Threshold GRASS6 key metrics values at 2007-04-16 are:
median | upper | outlier |
| quartile | limit |
Complexity (Cyclo): 5 | 25 | 37 |
ParamNBR: 2 | 6 | 9 |
CalledNBR: 10 | 60 | 87 |
LOC: 43 | 195 | 272 |
LOC: Lines Of Code
Message interpretation:
OK : Nothing to say at all
* : above 75 % of value warning
Brought to you by:
