[GRASS-QA] GRASS QA: scott | ./grass6/imagery/i.points/main.c |1
clones ( main.c main.c )| 0 monsters | 0 warnings
grass-qa at proxy.soccerlab.polymtl.ca
Thu Apr 19 12:45:01 EDT 2007
Hello scott,
ANALYSIS
imagery/i.points/main.c functions
main (Begins at: 39 Ends at: 164)
Complexity: | 11 | | OK |
ParamNBR: | 2 | | OK |
CalledNBR: | 58 | * | |
LOC: | 126 | * | |
metrics are OK
quit (Begins at: 166 Ends at: 189)
Complexity: | 2 | | OK |
ParamNBR: | 1 | | OK |
CalledNBR: | 14 | | OK |
LOC: | 24 | | OK |
metrics are OK
error (Begins at: 191 Ends at: 216)
Complexity: | 3 | | OK |
CalledNBR: | 16 | | OK |
LOC: | 26 | | OK |
metrics are OK
Clone analysis:
This file has 1 potentially cloned functions:
quit
In imagery/i.points/main.c clones of quit are:
imagery/i.vpoints/main.c quit
Threshold GRASS6 key metrics values at 2007-04-19 are:
median | upper | outlier |
| quartile | limit |
Complexity (Cyclo): 5 | 25 | 37 |
ParamNBR: 2 | 6 | 9 |
CalledNBR: 10 | 60 | 87 |
LOC: 43 | 195 | 273 |
LOC: Lines Of Code
Message interpretation:
OK : Nothing to say at all
* : above 75 % of value warning
Brought to you by:
