[GRASS-QA] GRASS QA: glynn | ./grass6/lib/gis/closecell.c |no
clones | 0 monsters | 3 warnings
grass-qa at proxy.soccerlab.polymtl.ca
Thu Apr 19 13:13:15 EDT 2007
Hello glynn,
ANALYSIS
lib/gis/closecell.c functions
G_close_cell (Begins at: 78 Ends at: 109)
Complexity: | 3 | | OK |
ParamNBR: | 1 | | OK |
CalledNBR: | 2 | | OK |
LOC: | 32 | | OK |
metrics are OK
G_unopen_cell (Begins at: 111 Ends at: 121)
LOC: | 11 | | OK |
metrics are OK
close_old (Begins at: 123 Ends at: 157)
Complexity: | 6 | | OK |
CalledNBR: | 11 | | OK |
LOC: | 35 | | OK |
metrics are OK
close_new (Begins at: 159 Ends at: 379)
Complexity: | 28 | ** | Warning |
ParamNBR: | 2 | | OK |
CalledNBR: | 74 | ** | Warning |
LOC: | 221 | ** | Warning |
at least 3 values are close to an outlier please consider revising code
G__write_fp_format (Begins at: 382 Ends at: 412)
Complexity: | 4 | | OK |
LOC: | 31 | | OK |
metrics are OK
Clone analysis:
This file does not contain cloned functions
Threshold GRASS6 key metrics values at 2007-04-19 are:
median | upper | outlier |
| quartile | limit |
Complexity (Cyclo): 5 | 25 | 37 |
ParamNBR: 2 | 6 | 9 |
CalledNBR: 10 | 60 | 87 |
LOC: 43 | 195 | 273 |
LOC: Lines Of Code
Message interpretation:
OK : Nothing to say at all
* : above 75 % of value warning
Brought to you by:
