[GRASS-QA] GRASS QA: scott | ./grass6/raster/r.out.ppm/main.c |no
clones | 0 monsters | 2 warnings
grass-qa at proxy.soccerlab.polymtl.ca
Thu Apr 19 13:44:58 EDT 2007
Hello scott,
ANALYSIS
raster/r.out.ppm/main.c functions
main (Begins at: 31 Ends at: 258)
Complexity: | 21 | * | |
ParamNBR: | 2 | | OK |
CalledNBR: | 84 | ** | Warning |
LOC: | 228 | ** | Warning |
at least 2 values are close to an outlier please consider revising code
Clone analysis:
This file does not contain cloned functions
Threshold GRASS6 key metrics values at 2007-04-19 are:
median | upper | outlier |
| quartile | limit |
Complexity (Cyclo): 5 | 25 | 37 |
ParamNBR: 2 | 6 | 9 |
CalledNBR: 10 | 60 | 87 |
LOC: 43 | 195 | 273 |
LOC: Lines Of Code
Message interpretation:
OK : Nothing to say at all
* : above 75 % of value warning
Brought to you by:
