[GRASS-QA] GRASS QA: scott | ./grass6/imagery/i.cca/main.c |no clones | 0 monsters | 1 warnings
Thu Apr 19 14:47:17 EDT 2007
Hello scott,
ANALYSIS
imagery/i.cca/main.c functions
main (Begins at: 47 Ends at: 216)
Complexity:   |      15 |       |      OK |
CalledNBR:    |      76 |    ** | Warning |
LOC:          |     170 |     * |         |
at least 1 values are close to an outlier please consider revising code
Clone analysis:
Threshold GRASS6 key metrics values at 2007-04-19 are:
                           | quartile  | limit   |
ParamNBR:                2 |         6 |       9 |
CalledNBR:              10 |        60 |      87 |
LOC:                    43 |       195 |     273 |
 LOC: Lines Of Code
Message interpretation:
 OK : Nothing to say at all
Brought to you by:
