[GRASS-QA] GRASS QA: glynn | ./grass6/lib/datetime/format.c |no
clones | 0 monsters | 2 warnings
grass-qa at proxy.soccerlab.polymtl.ca
Thu Apr 19 19:33:39 EDT 2007
Hello glynn,
ANALYSIS
lib/datetime/format.c functions
datetime_format (Begins at: 27 Ends at: 151)
Complexity: | 33 | ** | Warning |
ParamNBR: | 2 | | OK |
CalledNBR: | 61 | ** | Warning |
LOC: | 125 | * | |
at least 2 values are close to an outlier please consider revising code
Clone analysis:
This file does not contain cloned functions
Threshold GRASS6 key metrics values at 2007-04-19 are:
median | upper | outlier |
| quartile | limit |
Complexity (Cyclo): 5 | 25 | 37 |
ParamNBR: 2 | 6 | 9 |
CalledNBR: 10 | 60 | 87 |
LOC: 43 | 195 | 273 |
LOC: Lines Of Code
Message interpretation:
OK : Nothing to say at all
* : above 75 % of value warning
Brought to you by:
