[GRASS-QA] GRASS QA: glynn | ./grass6/lib/datetime/incr3.c |no clones | 0 monsters | 0 warnings
Thu Apr 19 19:33:40 EDT 2007
Hello glynn,
ANALYSIS
lib/datetime/incr3.c functions
datetime_get_increment_type (Begins at: 41 Ends at: 84)
Complexity:   |       4 |       |      OK |
ParamNBR:     |       5 |     * |         |
CalledNBR:    |       4 |       |      OK |
LOC:          |      44 |       |      OK |
metrics are OK
datetime_set_increment_type (Begins at: 87 Ends at: 94)
Complexity:   |       2 |       |      OK |
CalledNBR:    |       3 |       |      OK |
LOC:          |       8 |       |      OK |
metrics are OK
Clone analysis:
Threshold GRASS6 key metrics values at 2007-04-19 are:
                           | quartile  | limit   |
ParamNBR:                2 |         6 |       9 |
CalledNBR:              10 |        60 |      87 |
LOC:                    43 |       195 |     273 |
 LOC: Lines Of Code
Message interpretation:
 OK : Nothing to say at all
Brought to you by:
