[GRASS-QA] GRASS QA: glynn | ./grass6/lib/datetime/scan.c |no
clones | 0 monsters | 2 warnings
grass-qa at proxy.soccerlab.polymtl.ca
Thu Apr 19 19:33:40 EDT 2007
Hello glynn,
ANALYSIS
lib/datetime/scan.c functions
datetime_scan (Begins at: 43 Ends at: 54)
Complexity: | 4 | | OK |
ParamNBR: | 2 | | OK |
CalledNBR: | 5 | | OK |
LOC: | 12 | | OK |
metrics are OK
scan_absolute (Begins at: 60 Ends at: 157)
Complexity: | 37 | *** | MONSTER |
CalledNBR: | 26 | | OK |
LOC: | 98 | | OK |
at least 1 values are close to an outlier please consider revising code
scan_relative (Begins at: 160 Ends at: 217)
Complexity: | 29 | ** | Warning |
CalledNBR: | 12 | | OK |
LOC: | 58 | | OK |
is_space (Begins at: 219 Ends at: 222)
Complexity: | 1 | | OK |
ParamNBR: | 1 | | OK |
CalledNBR: | 0 | | OK |
LOC: | 4 | | OK |
metrics are OK
is_digit (Begins at: 224 Ends at: 227)
LOC: | 4 | | OK |
metrics are OK
skip_space (Begins at: 229 Ends at: 233)
Complexity: | 2 | | OK |
CalledNBR: | 1 | | OK |
LOC: | 5 | | OK |
metrics are OK
get_int (Begins at: 235 Ends at: 251)
ParamNBR: | 3 | | OK |
CalledNBR: | 2 | | OK |
LOC: | 17 | | OK |
metrics are OK
get_double (Begins at: 253 Ends at: 308)
ParamNBR: | 4 | | OK |
CalledNBR: | 4 | | OK |
LOC: | 56 | | OK |
metrics are OK
get_word (Begins at: 310 Ends at: 322)
CalledNBR: | 3 | | OK |
LOC: | 13 | | OK |
metrics are OK
lowercase (Begins at: 324 Ends at: 329)
LOC: | 6 | | OK |
metrics are OK
which_month (Begins at: 331 Ends at: 342)
LOC: | 12 | | OK |
metrics are OK
is_bc (Begins at: 344 Ends at: 356)
Complexity: | 3 | | OK |
LOC: | 13 | | OK |
metrics are OK
scan_tz (Begins at: 358 Ends at: 379)
Complexity: | 8 | | OK |
LOC: | 22 | | OK |
metrics are OK
relative_term (Begins at: 385 Ends at: 417)
ParamNBR: | 5 | * | |
CalledNBR: | 17 | | OK |
LOC: | 33 | | OK |
metrics are OK
minus_sign (Begins at: 419 Ends at: 428)
LOC: | 10 | | OK |
metrics are OK
is_relative (Begins at: 430 Ends at: 439)
LOC: | 10 | | OK |
metrics are OK
more (Begins at: 441 Ends at: 445)
LOC: | 5 | | OK |
metrics are OK
Clone analysis:
This file does not contain cloned functions
Threshold GRASS6 key metrics values at 2007-04-19 are:
median | upper | outlier |
| quartile | limit |
Complexity (Cyclo): 5 | 25 | 37 |
ParamNBR: 2 | 6 | 9 |
CalledNBR: 10 | 60 | 87 |
LOC: 43 | 195 | 273 |
LOC: Lines Of Code
Message interpretation:
OK : Nothing to say at all
* : above 75 % of value warning
Brought to you by:
