[GRASS-QA] GRASS QA: glynn | ./grass6/lib/edit/edit_cellhd.c |no
	clones | 3 monsters | 1 warnings
    grass-qa at proxy.soccerlab.polymtl.ca
    Thu Apr 19 20:09:22 EDT 2007
Hello glynn,
ANALYSIS
lib/edit/edit_cellhd.c functions
format_value (Begins at: 110 Ends at: 122)
Complexity:   |       2 |       |      OK |
ParamNBR:     |       7 |    ** | Warning |
CalledNBR:    |       1 |       |      OK |
LOC:          |      13 |       |      OK |
at least 1 values are close to an outlier please consider revising code
format_northing (Begins at: 125 Ends at: 128)
Complexity:   |       1 |       |      OK |
ParamNBR:     |       3 |       |      OK |
LOC:          |       4 |       |      OK |
metrics are OK
format_easting (Begins at: 131 Ends at: 134)
LOC:          |       4 |       |      OK |
metrics are OK
format_resolution (Begins at: 137 Ends at: 140)
LOC:          |       4 |       |      OK |
metrics are OK
E_edit_cellhd (Begins at: 143 Ends at: 533)
Complexity:   |      59 |   *** | MONSTER |
CalledNBR:    |     119 |   *** | MONSTER |
LOC:          |     391 |   *** | MONSTER |
3 metric are OUT OF RANGE!
hitreturn (Begins at: 536 Ends at: 549)
Complexity:   |       3 |       |      OK |
ParamNBR:     |       1 |       |      OK |
CalledNBR:    |       6 |       |      OK |
LOC:          |      14 |       |      OK |
metrics are OK
Clone analysis:
Threshold GRASS6 key metrics values at 2007-04-19 are:
                           | quartile  | limit   |
ParamNBR:                2 |         6 |       9 |
CalledNBR:              10 |        60 |      87 |
LOC:                    43 |       195 |     273 |
 LOC: Lines Of Code
Message interpretation:
 OK : Nothing to say at all
Brought to you by:
