[GRASS-QA] GRASS QA: glynn | ./grass6/lib/rowio/get.c |no clones |
0 monsters | 0 warnings
grass-qa at proxy.soccerlab.polymtl.ca
Thu Apr 19 20:30:22 EDT 2007
Hello glynn,
ANALYSIS
lib/rowio/get.c functions
rowio_get (Begins at: 31 Ends at: 75)
Complexity: | 8 | | OK |
ParamNBR: | 2 | | OK |
CalledNBR: | 4 | | OK |
LOC: | 45 | | OK |
metrics are OK
rowio_flush (Begins at: 77 Ends at: 83)
Complexity: | 1 | | OK |
ParamNBR: | 1 | | OK |
CalledNBR: | 1 | | OK |
LOC: | 7 | | OK |
metrics are OK
pageout (Begins at: 85 Ends at: 93)
Complexity: | 3 | | OK |
LOC: | 9 | | OK |
metrics are OK
my_select (Begins at: 95 Ends at: 105)
CalledNBR: | 0 | | OK |
LOC: | 11 | | OK |
metrics are OK
Clone analysis:
This file does not contain cloned functions
Threshold GRASS6 key metrics values at 2007-04-19 are:
median | upper | outlier |
| quartile | limit |
Complexity (Cyclo): 5 | 25 | 37 |
ParamNBR: 2 | 6 | 9 |
CalledNBR: 10 | 60 | 87 |
LOC: 43 | 195 | 273 |
LOC: Lines Of Code
Message interpretation:
OK : Nothing to say at all
* : above 75 % of value warning
Brought to you by:
