[GRASS-QA] GRASS QA: glynn | ./grass6/raster/r.mapcalc/map.c |6
clones ( map.c )| 0 monsters | 1 warnings
grass-qa at proxy.soccerlab.polymtl.ca
Thu Apr 19 20:30:23 EDT 2007
Hello glynn,
ANALYSIS
raster/r.mapcalc/map.c functions
setup_region (Begins at: 19 Ends at: 26)
Complexity: | 1 | | OK |
ParamNBR: | 1 | | OK |
CalledNBR: | 3 | | OK |
LOC: | 8 | | OK |
metrics are OK
compare_ints (Begins at: 65 Ends at: 68)
ParamNBR: | 2 | | OK |
CalledNBR: | 0 | | OK |
LOC: | 4 | | OK |
metrics are OK
init_colors (Begins at: 70 Ends at: 82)
Complexity: | 6 | | OK |
CalledNBR: | 6 | | OK |
LOC: | 13 | | OK |
metrics are OK
init_cats (Begins at: 84 Ends at: 95)
Complexity: | 3 | | OK |
CalledNBR: | 4 | | OK |
LOC: | 12 | | OK |
metrics are OK
translate_from_colors (Begins at: 97 Ends at: 160)
Complexity: | 11 | | OK |
ParamNBR: | 5 | * | |
CalledNBR: | 2 | | OK |
LOC: | 64 | | OK |
metrics are OK
translate_from_cats (Begins at: 162 Ends at: 218)
ParamNBR: | 4 | | OK |
CalledNBR: | 9 | | OK |
LOC: | 57 | | OK |
metrics are OK
set_read_row_type (Begins at: 220 Ends at: 223)
LOC: | 4 | | OK |
metrics are OK
read_row (Begins at: 225 Ends at: 231)
Complexity: | 2 | | OK |
LOC: | 7 | | OK |
metrics are OK
setup_map (Begins at: 233 Ends at: 249)
LOC: | 17 | | OK |
metrics are OK
read_map (Begins at: 251 Ends at: 299)
Complexity: | 10 | | OK |
CalledNBR: | 11 | | OK |
LOC: | 49 | | OK |
metrics are OK
close_map (Begins at: 301 Ends at: 328)
LOC: | 28 | | OK |
metrics are OK
map_type (Begins at: 332 Ends at: 358)
CalledNBR: | 5 | | OK |
LOC: | 27 | | OK |
metrics are OK
open_map (Begins at: 360 Ends at: 445)
Complexity: | 25 | * | |
CalledNBR: | 12 | | OK |
LOC: | 86 | | OK |
metrics are OK
setup_maps (Begins at: 447 Ends at: 453)
CalledNBR: | 1 | | OK |
LOC: | 7 | | OK |
metrics are OK
get_map_row (Begins at: 455 Ends at: 488)
Complexity: | 13 | | OK |
ParamNBR: | 7 | ** | Warning |
CalledNBR: | 8 | | OK |
LOC: | 34 | | OK |
at least 1 values are close to an outlier please consider revising code
close_maps (Begins at: 490 Ends at: 498)
LOC: | 9 | | OK |
metrics are OK
open_output_map (Begins at: 502 Ends at: 511)
LOC: | 10 | | OK |
metrics are OK
put_map_row (Begins at: 513 Ends at: 517)
ParamNBR: | 3 | | OK |
LOC: | 5 | | OK |
metrics are OK
close_output_map (Begins at: 519 Ends at: 523)
LOC: | 5 | | OK |
metrics are OK
unopen_output_map (Begins at: 525 Ends at: 528)
LOC: | 4 | | OK |
metrics are OK
copy_cats (Begins at: 532 Ends at: 542)
LOC: | 11 | | OK |
metrics are OK
copy_colors (Begins at: 544 Ends at: 554)
LOC: | 11 | | OK |
metrics are OK
copy_history (Begins at: 556 Ends at: 565)
LOC: | 10 | | OK |
metrics are OK
create_history (Begins at: 567 Ends at: 610)
Complexity: | 4 | | OK |
LOC: | 44 | | OK |
metrics are OK
Clone analysis:
This file has 6 potentially cloned functions:
init_cats copy_colors init_colors translate_from_colors copy_cats translate_from_cats
In raster/r.mapcalc/map.c clones of copy_cats are:
raster/r.mapcalc/map3.c copy_cats
In raster/r.mapcalc/map.c clones of init_cats are:
raster/r.mapcalc/map3.c init_cats
In raster/r.mapcalc/map.c clones of translate_from_cats are:
raster/r.mapcalc/map3.c translate_from_cats
In raster/r.mapcalc/map.c clones of init_colors are:
raster/r.mapcalc/map3.c init_colors
In raster/r.mapcalc/map.c clones of copy_colors are:
raster/r.mapcalc/map3.c copy_colors
In raster/r.mapcalc/map.c clones of translate_from_colors are:
raster/r.mapcalc/map3.c translate_from_colors
Threshold GRASS6 key metrics values at 2007-04-19 are:
median | upper | outlier |
| quartile | limit |
Complexity (Cyclo): 5 | 25 | 37 |
ParamNBR: 2 | 6 | 9 |
CalledNBR: 10 | 60 | 87 |
LOC: 43 | 195 | 273 |
LOC: Lines Of Code
Message interpretation:
OK : Nothing to say at all
* : above 75 % of value warning
Brought to you by:
