[GRASS-QA] GRASS QA: scott | ./grass6/display/d.font/main.c |no
clones | 0 monsters | 0 warnings
grass-qa at proxy.soccerlab.polymtl.ca
Fri Apr 20 00:06:59 EDT 2007
Hello scott,
ANALYSIS
display/d.font/main.c functions
main (Begins at: 37 Ends at: 110)
Complexity: | 7 | | OK |
ParamNBR: | 2 | | OK |
CalledNBR: | 30 | | OK |
LOC: | 74 | | OK |
metrics are OK
read_stroke_fonts (Begins at: 112 Ends at: 150)
Complexity: | 6 | | OK |
ParamNBR: | 1 | | OK |
CalledNBR: | 9 | | OK |
LOC: | 39 | | OK |
metrics are OK
read_freetype_fonts (Begins at: 152 Ends at: 209)
Complexity: | 11 | | OK |
CalledNBR: | 16 | | OK |
LOC: | 58 | | OK |
metrics are OK
make_font_list (Begins at: 211 Ends at: 237)
Complexity: | 2 | | OK |
CalledNBR: | 2 | | OK |
LOC: | 27 | | OK |
metrics are OK
print_font_list (Begins at: 239 Ends at: 245)
Complexity: | 1 | | OK |
CalledNBR: | 1 | | OK |
LOC: | 7 | | OK |
metrics are OK
Clone analysis:
This file does not contain cloned functions
Threshold GRASS6 key metrics values at 2007-04-19 are:
median | upper | outlier |
| quartile | limit |
Complexity (Cyclo): 5 | 25 | 37 |
ParamNBR: 2 | 6 | 9 |
CalledNBR: 10 | 60 | 87 |
LOC: 43 | 195 | 273 |
LOC: Lines Of Code
Message interpretation:
OK : Nothing to say at all
* : above 75 % of value warning
Brought to you by:
