[GRASS-QA] GRASS QA: scott |
./grass6/display/drivers/XDRIVER/main.c |1 clones ( main.c
main.c main.c main.c )| 0 monsters | 0 warnings
grass-qa at proxy.soccerlab.polymtl.ca
Fri Apr 20 00:06:59 EDT 2007
Hello scott,
ANALYSIS
display/drivers/XDRIVER/main.c functions
main (Begins at: 19 Ends at: 59)
Complexity: | 1 | | OK |
ParamNBR: | 2 | | OK |
CalledNBR: | 2 | | OK |
LOC: | 41 | | OK |
metrics are OK
Clone analysis:
This file has 1 potentially cloned functions:
main
In display/drivers/XDRIVER/main.c clones of main are:
display/drivers/HTMLMAP/main.c main
Threshold GRASS6 key metrics values at 2007-04-19 are:
median | upper | outlier |
| quartile | limit |
Complexity (Cyclo): 5 | 25 | 37 |
ParamNBR: 2 | 6 | 9 |
CalledNBR: 10 | 60 | 87 |
LOC: 43 | 195 | 273 |
LOC: Lines Of Code
Message interpretation:
OK : Nothing to say at all
* : above 75 % of value warning
Brought to you by:
