[GRASS-QA] GRASS QA: glynn | ./grass6/lib/gis/reclass.c |no clones | 0 monsters | 0 warnings
Fri Apr 20 13:58:10 EDT 2007
Hello glynn,
ANALYSIS
lib/gis/reclass.c functions
G_is_reclass (Begins at: 30 Ends at: 63)
Complexity:   |       3 |       |      OK |
ParamNBR:     |       4 |       |      OK |
CalledNBR:    |       3 |       |      OK |
LOC:          |      34 |       |      OK |
metrics are OK
G_is_reclassed_to (Begins at: 65 Ends at: 118)
Complexity:   |       9 |       |      OK |
CalledNBR:    |       8 |       |      OK |
LOC:          |      54 |       |      OK |
metrics are OK
G_get_reclass (Begins at: 120 Ends at: 158)
Complexity:   |       8 |       |      OK |
ParamNBR:     |       3 |       |      OK |
CalledNBR:    |       9 |       |      OK |
LOC:          |      39 |       |      OK |
metrics are OK
G_free_reclass (Begins at: 160 Ends at: 180)
Complexity:   |       7 |       |      OK |
ParamNBR:     |       1 |       |      OK |
LOC:          |      21 |       |      OK |
metrics are OK
reclass_type (Begins at: 182 Ends at: 229)
Complexity:   |      12 |       |      OK |
CalledNBR:    |      10 |       |      OK |
LOC:          |      48 |       |      OK |
metrics are OK
fopen_cellhd_old (Begins at: 231 Ends at: 234)
Complexity:   |       1 |       |      OK |
CalledNBR:    |       1 |       |      OK |
LOC:          |       4 |       |      OK |
metrics are OK
G_put_reclass (Begins at: 236 Ends at: 336)
Complexity:   |      15 |       |      OK |
CalledNBR:    |      32 |       |      OK |
LOC:          |     101 |       |      OK |
metrics are OK
fopen_cellhd_new (Begins at: 338 Ends at: 341)
LOC:          |       4 |       |      OK |
metrics are OK
get_reclass_table (Begins at: 343 Ends at: 393)
LOC:          |      51 |       |      OK |
metrics are OK
Clone analysis:
Threshold GRASS6 key metrics values at 2007-04-20 are:
                           | quartile  | limit   |
ParamNBR:                2 |         6 |       9 |
CalledNBR:              10 |        60 |      87 |
LOC:                    43 |       195 |     273 |
 LOC: Lines Of Code
Message interpretation:
 OK : Nothing to say at all
Brought to you by:
