[GRASS-QA] GRASS QA: glynn | ./grass6/lib/segment/format.c |no clones | 0 monsters | 1 warnings
Fri Apr 20 17:58:20 EDT 2007
Hello glynn,
ANALYSIS
lib/segment/format.c functions
segment_format (Begins at: 60 Ends at: 97)
Complexity:   |       1 |       |      OK |
ParamNBR:     |       6 |     * |         |
CalledNBR:    |       1 |       |      OK |
LOC:          |      38 |       |      OK |
metrics are OK
segment_format_nofill (Begins at: 99 Ends at: 102)
LOC:          |       4 |       |      OK |
metrics are OK
_segment_format (Begins at: 105 Ends at: 153)
Complexity:   |       7 |       |      OK |
ParamNBR:     |       7 |    ** | Warning |
CalledNBR:    |      11 |       |      OK |
LOC:          |      49 |       |      OK |
at least 1 values are close to an outlier please consider revising code
write_int (Begins at: 156 Ends at: 167)
Complexity:   |       2 |       |      OK |
CalledNBR:    |       4 |       |      OK |
LOC:          |      12 |       |      OK |
metrics are OK
zero_fill (Begins at: 170 Ends at: 215)
Complexity:   |       4 |       |      OK |
LOC:          |      46 |       |      OK |
metrics are OK
Clone analysis:
Threshold GRASS6 key metrics values at 2007-04-20 are:
                           | quartile  | limit   |
ParamNBR:                2 |         6 |       9 |
CalledNBR:              10 |        60 |      87 |
LOC:                    43 |       195 |     273 |
 LOC: Lines Of Code
Message interpretation:
 OK : Nothing to say at all
Brought to you by:
