[GRASS-QA] GRASS QA: glynn | ./grass6/lib/imagery/sigset.c |2 clones ( sigset.c )| 0 monsters | 0 warnings
Sat Apr 21 03:17:22 EDT 2007
Hello glynn,
ANALYSIS
lib/imagery/sigset.c functions
alloc_matrix (Begins at: 18 Ends at: 29)
Complexity:   |       1 |       |      OK |
CalledNBR:    |       2 |       |      OK |
LOC:          |      12 |       |      OK |
metrics are OK
I_SigSetNClasses (Begins at: 31 Ends at: 40)
Complexity:   |       2 |       |      OK |
ParamNBR:     |       1 |       |      OK |
CalledNBR:    |       0 |       |      OK |
LOC:          |      10 |       |      OK |
metrics are OK
I_AllocClassData (Begins at: 44 Ends at: 57)
ParamNBR:     |       3 |       |      OK |
LOC:          |      14 |       |      OK |
metrics are OK
I_InitSigSet (Begins at: 59 Ends at: 67)
LOC:          |       9 |       |      OK |
metrics are OK
I_SigSetNBands (Begins at: 69 Ends at: 74)
LOC:          |       6 |       |      OK |
metrics are OK
I_NewClassSig (Begins at: 77 Ends at: 93)
LOC:          |      17 |       |      OK |
metrics are OK
I_NewSubSig (Begins at: 96 Ends at: 122)
CalledNBR:    |       7 |       |      OK |
LOC:          |      27 |       |      OK |
metrics are OK
I_ReadSigSet (Begins at: 126 Ends at: 142)
Complexity:   |       5 |       |      OK |
CalledNBR:    |       8 |       |      OK |
LOC:          |      17 |       |      OK |
metrics are OK
gettag (Begins at: 144 Ends at: 150)
LOC:          |       7 |       |      OK |
metrics are OK
get_nbands (Begins at: 152 Ends at: 157)
CalledNBR:    |       1 |       |      OK |
LOC:          |       6 |       |      OK |
metrics are OK
get_title (Begins at: 159 Ends at: 168)
LOC:          |      10 |       |      OK |
metrics are OK
get_class (Begins at: 170 Ends at: 191)
Complexity:   |       7 |       |      OK |
CalledNBR:    |      11 |       |      OK |
LOC:          |      22 |       |      OK |
metrics are OK
get_classnum (Begins at: 193 Ends at: 198)
LOC:          |       6 |       |      OK |
metrics are OK
get_classtype (Begins at: 200 Ends at: 205)
LOC:          |       6 |       |      OK |
metrics are OK
get_classtitle (Begins at: 207 Ends at: 216)
LOC:          |      10 |       |      OK |
metrics are OK
get_subclass (Begins at: 218 Ends at: 238)
Complexity:   |       6 |       |      OK |
CalledNBR:    |       9 |       |      OK |
LOC:          |      21 |       |      OK |
metrics are OK
get_subclass_pi (Begins at: 241 Ends at: 248)
LOC:          |       8 |       |      OK |
metrics are OK
get_subclass_means (Begins at: 251 Ends at: 262)
LOC:          |      12 |       |      OK |
metrics are OK
get_subclass_covar (Begins at: 265 Ends at: 277)
LOC:          |      13 |       |      OK |
metrics are OK
I_SetSigTitle (Begins at: 279 Ends at: 290)
Complexity:   |       3 |       |      OK |
CalledNBR:    |       4 |       |      OK |
LOC:          |      12 |       |      OK |
metrics are OK
I_GetSigTitle (Begins at: 292 Ends at: 298)
LOC:          |       7 |       |      OK |
metrics are OK
I_SetClassTitle (Begins at: 300 Ends at: 311)
LOC:          |      12 |       |      OK |
metrics are OK
I_GetClassTitle (Begins at: 313 Ends at: 319)
LOC:          |       7 |       |      OK |
metrics are OK
I_WriteSigSet (Begins at: 321 Ends at: 364)
CalledNBR:    |      19 |       |      OK |
LOC:          |      44 |       |      OK |
metrics are OK
Clone analysis:
This file has 2 potentially cloned functions:
  get_classtitle  get_title
In lib/imagery/sigset.c clones of  get_classtitle are:
	lib/imagery/sigset.c  get_title
In lib/imagery/sigset.c clones of  get_title are:
	lib/imagery/sigset.c  get_classtitle
Threshold GRASS6 key metrics values at 2007-04-21 are:
                           | quartile  | limit   |
ParamNBR:                2 |         6 |       9 |
CalledNBR:              10 |        60 |      87 |
LOC:                    43 |       195 |     273 |
 LOC: Lines Of Code
Message interpretation:
 OK : Nothing to say at all
Brought to you by:
