[GRASS-QA] GRASS QA: glynn | ./grass6/lib/vask/V_ques.c |no clones | 0 monsters | 0 warnings
Sat Apr 21 03:17:40 EDT 2007
Hello glynn,
ANALYSIS
lib/vask/V_ques.c functions
V_ques (Begins at: 77 Ends at: 125)
Complexity:   |       7 |       |      OK |
ParamNBR:     |       5 |     * |         |
CalledNBR:    |       5 |       |      OK |
LOC:          |      49 |       |      OK |
metrics are OK
Clone analysis:
Threshold GRASS6 key metrics values at 2007-04-21 are:
                           | quartile  | limit   |
ParamNBR:                2 |         6 |       9 |
CalledNBR:              10 |        60 |      87 |
LOC:                    43 |       195 |     273 |
 LOC: Lines Of Code
Message interpretation:
 OK : Nothing to say at all
Brought to you by:
