[GRASS-QA] GRASS QA: glynn | ./grass6/lib/vask/V_ques.c |no clones
| 0 monsters | 0 warnings
grass-qa at proxy.soccerlab.polymtl.ca
Sat Apr 21 03:17:24 EDT 2007
Hello glynn,
ANALYSIS
lib/vask/V_ques.c functions
V_ques (Begins at: 77 Ends at: 125)
Complexity: | 7 | | OK |
ParamNBR: | 5 | * | |
CalledNBR: | 5 | | OK |
LOC: | 49 | | OK |
metrics are OK
Clone analysis:
This file does not contain cloned functions
Threshold GRASS6 key metrics values at 2007-04-21 are:
median | upper | outlier |
| quartile | limit |
Complexity (Cyclo): 5 | 25 | 37 |
ParamNBR: 2 | 6 | 9 |
CalledNBR: 10 | 60 | 87 |
LOC: 43 | 195 | 273 |
LOC: Lines Of Code
Message interpretation:
OK : Nothing to say at all
* : above 75 % of value warning
Brought to you by:
