[GRASS-QA] GRASS QA: glynn | ./grass6/raster/r.mapcalc/map.c |6 clones ( map3.c map.c )| 0 monsters | 1 warnings
Sat Apr 21 16:56:31 EDT 2007
Hello glynn,
ANALYSIS
raster/r.mapcalc/map.c functions
setup_region (Begins at: 19 Ends at: 26)
Complexity:   |       1 |       |      OK |
ParamNBR:     |       1 |       |      OK |
CalledNBR:    |       3 |       |      OK |
LOC:          |       8 |       |      OK |
metrics are OK
compare_ints (Begins at: 65 Ends at: 68)
CalledNBR:    |       0 |       |      OK |
LOC:          |       4 |       |      OK |
metrics are OK
init_colors (Begins at: 70 Ends at: 82)
Complexity:   |       6 |       |      OK |
CalledNBR:    |       6 |       |      OK |
LOC:          |      13 |       |      OK |
metrics are OK
init_cats (Begins at: 84 Ends at: 95)
Complexity:   |       3 |       |      OK |
CalledNBR:    |       4 |       |      OK |
LOC:          |      12 |       |      OK |
metrics are OK
translate_from_colors (Begins at: 97 Ends at: 160)
Complexity:   |      11 |       |      OK |
ParamNBR:     |       5 |     * |         |
CalledNBR:    |       2 |       |      OK |
LOC:          |      64 |       |      OK |
metrics are OK
translate_from_cats (Begins at: 162 Ends at: 222)
ParamNBR:     |       4 |       |      OK |
CalledNBR:    |       9 |       |      OK |
LOC:          |      61 |       |      OK |
metrics are OK
set_read_row_type (Begins at: 224 Ends at: 227)
LOC:          |       4 |       |      OK |
metrics are OK
read_row (Begins at: 229 Ends at: 235)
Complexity:   |       2 |       |      OK |
LOC:          |       7 |       |      OK |
metrics are OK
setup_map (Begins at: 237 Ends at: 253)
LOC:          |      17 |       |      OK |
metrics are OK
read_map (Begins at: 255 Ends at: 303)
Complexity:   |      10 |       |      OK |
CalledNBR:    |      11 |       |      OK |
LOC:          |      49 |       |      OK |
metrics are OK
close_map (Begins at: 305 Ends at: 332)
LOC:          |      28 |       |      OK |
metrics are OK
map_type (Begins at: 336 Ends at: 362)
CalledNBR:    |       5 |       |      OK |
LOC:          |      27 |       |      OK |
metrics are OK
open_map (Begins at: 364 Ends at: 449)
Complexity:   |      25 |     * |         |
CalledNBR:    |      12 |       |      OK |
LOC:          |      86 |       |      OK |
metrics are OK
setup_maps (Begins at: 451 Ends at: 457)
CalledNBR:    |       1 |       |      OK |
LOC:          |       7 |       |      OK |
metrics are OK
get_map_row (Begins at: 459 Ends at: 492)
Complexity:   |      13 |       |      OK |
ParamNBR:     |       7 |    ** | Warning |
CalledNBR:    |       8 |       |      OK |
LOC:          |      34 |       |      OK |
at least 1 values are close to an outlier please consider revising code
close_maps (Begins at: 494 Ends at: 502)
LOC:          |       9 |       |      OK |
metrics are OK
open_output_map (Begins at: 506 Ends at: 515)
LOC:          |      10 |       |      OK |
metrics are OK
put_map_row (Begins at: 517 Ends at: 521)
ParamNBR:     |       3 |       |      OK |
LOC:          |       5 |       |      OK |
metrics are OK
close_output_map (Begins at: 523 Ends at: 527)
LOC:          |       5 |       |      OK |
metrics are OK
unopen_output_map (Begins at: 529 Ends at: 532)
LOC:          |       4 |       |      OK |
metrics are OK
copy_cats (Begins at: 536 Ends at: 546)
LOC:          |      11 |       |      OK |
metrics are OK
copy_colors (Begins at: 548 Ends at: 558)
LOC:          |      11 |       |      OK |
metrics are OK
copy_history (Begins at: 560 Ends at: 569)
LOC:          |      10 |       |      OK |
metrics are OK
create_history (Begins at: 571 Ends at: 614)
Complexity:   |       4 |       |      OK |
LOC:          |      44 |       |      OK |
metrics are OK
Clone analysis:
This file has 6 potentially cloned functions:
  init_cats  copy_colors  translate_from_cats  copy_cats  translate_from_colors  init_colors
In raster/r.mapcalc/map.c clones of  copy_cats are:
	raster/r.mapcalc/map3.c  copy_cats
In raster/r.mapcalc/map.c clones of  init_cats are:
	raster/r.mapcalc/map3.c  init_cats
In raster/r.mapcalc/map.c clones of  init_colors are:
	raster/r.mapcalc/map3.c  init_colors
In raster/r.mapcalc/map.c clones of  translate_from_cats are:
	raster/r.mapcalc/map3.c  translate_from_cats
In raster/r.mapcalc/map.c clones of  copy_colors are:
	raster/r.mapcalc/map3.c  copy_colors
In raster/r.mapcalc/map.c clones of  translate_from_colors are:
	raster/r.mapcalc/map3.c  translate_from_colors
Threshold GRASS6 key metrics values at 2007-04-21 are:
                           | quartile  | limit   |
ParamNBR:                2 |         6 |       9 |
CalledNBR:              10 |        60 |      87 |
LOC:                    43 |       195 |     273 |
 LOC: Lines Of Code
Message interpretation:
 OK : Nothing to say at all
Brought to you by:
