[GRASS-QA] GRASS QA: glynn | ./grass6/lib/raster/loc_proto.c |6
clones ( com_proto.c loc_proto.c )| 0 monsters | 0 warnings
grass-qa at proxy.soccerlab.polymtl.ca
Sat Apr 21 19:34:31 EDT 2007
Hello glynn,
ANALYSIS
lib/raster/loc_proto.c functions
LOC_screen_left (Begins at: 25 Ends at: 41)
Complexity: | 1 | | OK |
ParamNBR: | 1 | | OK |
CalledNBR: | 1 | | OK |
LOC: | 17 | | OK |
metrics are OK
LOC_screen_rite (Begins at: 43 Ends at: 59)
LOC: | 17 | | OK |
metrics are OK
LOC_screen_bot (Begins at: 61 Ends at: 78)
LOC: | 18 | | OK |
metrics are OK
LOC_screen_top (Begins at: 80 Ends at: 87)
LOC: | 8 | | OK |
metrics are OK
LOC_get_num_colors (Begins at: 89 Ends at: 104)
LOC: | 16 | | OK |
metrics are OK
LOC_standard_color (Begins at: 106 Ends at: 123)
LOC: | 18 | | OK |
metrics are OK
LOC_RGB_color (Begins at: 125 Ends at: 137)
ParamNBR: | 3 | | OK |
LOC: | 13 | | OK |
metrics are OK
LOC_line_width (Begins at: 139 Ends at: 151)
LOC: | 13 | | OK |
metrics are OK
LOC_erase (Begins at: 153 Ends at: 167)
LOC: | 15 | | OK |
metrics are OK
LOC_move_abs (Begins at: 169 Ends at: 187)
ParamNBR: | 2 | | OK |
LOC: | 19 | | OK |
metrics are OK
LOC_move_rel (Begins at: 189 Ends at: 204)
LOC: | 16 | | OK |
metrics are OK
LOC_cont_abs (Begins at: 206 Ends at: 226)
LOC: | 21 | | OK |
metrics are OK
LOC_cont_rel (Begins at: 228 Ends at: 244)
LOC: | 17 | | OK |
metrics are OK
LOC_polydots_abs (Begins at: 246 Ends at: 264)
LOC: | 19 | | OK |
metrics are OK
LOC_polydots_rel (Begins at: 266 Ends at: 285)
LOC: | 20 | | OK |
metrics are OK
LOC_polyline_abs (Begins at: 287 Ends at: 307)
LOC: | 21 | | OK |
metrics are OK
LOC_polyline_rel (Begins at: 309 Ends at: 325)
LOC: | 17 | | OK |
metrics are OK
LOC_polygon_abs (Begins at: 327 Ends at: 345)
LOC: | 19 | | OK |
metrics are OK
LOC_polygon_rel (Begins at: 347 Ends at: 364)
LOC: | 18 | | OK |
metrics are OK
LOC_box_abs (Begins at: 366 Ends at: 382)
ParamNBR: | 4 | | OK |
LOC: | 17 | | OK |
metrics are OK
LOC_box_rel (Begins at: 384 Ends at: 397)
LOC: | 14 | | OK |
metrics are OK
LOC_text_size (Begins at: 399 Ends at: 402)
LOC: | 4 | | OK |
metrics are OK
LOC_text_rotation (Begins at: 404 Ends at: 420)
LOC: | 17 | | OK |
metrics are OK
LOC_set_window (Begins at: 422 Ends at: 435)
LOC: | 14 | | OK |
metrics are OK
LOC_text (Begins at: 437 Ends at: 457)
LOC: | 21 | | OK |
metrics are OK
LOC_get_text_box (Begins at: 459 Ends at: 494)
ParamNBR: | 5 | * | |
LOC: | 36 | | OK |
metrics are OK
LOC_font (Begins at: 496 Ends at: 499)
LOC: | 4 | | OK |
metrics are OK
LOC_charset (Begins at: 501 Ends at: 504)
LOC: | 4 | | OK |
metrics are OK
LOC_panel_save (Begins at: 506 Ends at: 512)
CalledNBR: | 4 | | OK |
LOC: | 7 | | OK |
metrics are OK
LOC_panel_restore (Begins at: 514 Ends at: 518)
CalledNBR: | 2 | | OK |
LOC: | 5 | | OK |
metrics are OK
LOC_panel_delete (Begins at: 520 Ends at: 526)
CalledNBR: | 3 | | OK |
LOC: | 7 | | OK |
metrics are OK
LOC_begin_scaled_raster (Begins at: 528 Ends at: 531)
LOC: | 4 | | OK |
metrics are OK
LOC_scaled_raster (Begins at: 533 Ends at: 538)
ParamNBR: | 6 | * | |
LOC: | 6 | | OK |
metrics are OK
LOC_bitmap (Begins at: 540 Ends at: 543)
LOC: | 4 | | OK |
metrics are OK
Clone analysis:
This file has 6 potentially cloned functions:
LOC_cont_rel LOC_box_abs LOC_polyline_abs LOC_get_text_box LOC_box_rel LOC_set_window
In lib/raster/loc_proto.c clones of LOC_polyline_abs are:
In lib/raster/loc_proto.c clones of LOC_cont_rel are:
lib/raster/com_proto.c R_cont_rel
In lib/raster/loc_proto.c clones of LOC_get_text_box are:
lib/raster/com_proto.c R_get_text_box
In lib/raster/loc_proto.c clones of LOC_set_window are:
lib/raster/com_proto.c R_set_window
In lib/raster/loc_proto.c clones of LOC_box_rel are:
lib/raster/com_proto.c R_box_rel
In lib/raster/loc_proto.c clones of LOC_box_abs are:
lib/raster/com_proto.c R_box_abs
Threshold GRASS6 key metrics values at 2007-04-21 are:
median | upper | outlier |
| quartile | limit |
Complexity (Cyclo): 5 | 25 | 37 |
ParamNBR: 2 | 6 | 9 |
CalledNBR: 10 | 60 | 87 |
LOC: 43 | 195 | 273 |
LOC: Lines Of Code
Message interpretation:
OK : Nothing to say at all
* : above 75 % of value warning
Brought to you by:
