[GRASS-QA] GRASS QA: glynn | ./grass6/lib/display/draw.c |no clones | 0 monsters | 1 warnings
Sun Apr 22 03:18:49 EDT 2007
Hello glynn,
ANALYSIS
lib/display/draw.c functions
D_set_clip_window (Begins at: 60 Ends at: 95)
Complexity:   |       3 |       |      OK |
ParamNBR:     |       4 |       |      OK |
CalledNBR:    |       2 |       |      OK |
LOC:          |      36 |       |      OK |
metrics are OK
D_set_clip_window_to_map_window (Begins at: 97 Ends at: 118)
Complexity:   |       1 |       |      OK |
ParamNBR:     |       1 |       |      OK |
CalledNBR:    |       5 |       |      OK |
LOC:          |      22 |       |      OK |
metrics are OK
D_set_clip_window_to_screen_window (Begins at: 120 Ends at: 142)
LOC:          |      23 |       |      OK |
metrics are OK
D_cont_abs (Begins at: 144 Ends at: 179)
CalledNBR:    |       4 |       |      OK |
LOC:          |      36 |       |      OK |
metrics are OK
D_cont_rel (Begins at: 181 Ends at: 196)
CalledNBR:    |       1 |       |      OK |
LOC:          |      16 |       |      OK |
metrics are OK
D_move_abs (Begins at: 198 Ends at: 216)
CalledNBR:    |       0 |       |      OK |
LOC:          |      19 |       |      OK |
metrics are OK
D_move_rel (Begins at: 218 Ends at: 232)
LOC:          |      15 |       |      OK |
metrics are OK
clip (Begins at: 234 Ends at: 373)
Complexity:   |      27 |    ** | Warning |
CalledNBR:    |       8 |       |      OK |
LOC:          |     140 |     * |         |
at least 1 values are close to an outlier please consider revising code
line_eq (Begins at: 375 Ends at: 383)
Complexity:   |       2 |       |      OK |
ParamNBR:     |       6 |     * |         |
LOC:          |       9 |       |      OK |
metrics are OK
Clone analysis:
Threshold GRASS6 key metrics values at 2007-04-22 are:
                           | quartile  | limit   |
ParamNBR:                2 |         6 |       9 |
CalledNBR:              10 |        60 |      87 |
LOC:                    43 |       195 |     273 |
 LOC: Lines Of Code
Message interpretation:
 OK : Nothing to say at all
Brought to you by:
