[GRASS-QA] GRASS QA: glynn | ./grass6/lib/display/raster2.c |no
clones | 0 monsters | 0 warnings
grass-qa at proxy.soccerlab.polymtl.ca
Sun Apr 22 03:18:49 EDT 2007
Hello glynn,
ANALYSIS
lib/display/raster2.c functions
D_set_overlay_mode (Begins at: 49 Ends at: 65)
Complexity: | 1 | | OK |
ParamNBR: | 1 | | OK |
CalledNBR: | 0 | | OK |
LOC: | 17 | | OK |
metrics are OK
D_color (Begins at: 67 Ends at: 72)
ParamNBR: | 2 | | OK |
CalledNBR: | 1 | | OK |
LOC: | 6 | | OK |
metrics are OK
D_c_color (Begins at: 75 Ends at: 93)
LOC: | 19 | | OK |
metrics are OK
D_d_color (Begins at: 95 Ends at: 113)
LOC: | 19 | | OK |
metrics are OK
D_f_color (Begins at: 115 Ends at: 137)
LOC: | 23 | | OK |
metrics are OK
D_color_of_type (Begins at: 139 Ends at: 149)
ParamNBR: | 3 | | OK |
CalledNBR: | 2 | | OK |
LOC: | 11 | | OK |
metrics are OK
Clone analysis:
This file does not contain cloned functions
Threshold GRASS6 key metrics values at 2007-04-22 are:
median | upper | outlier |
| quartile | limit |
Complexity (Cyclo): 5 | 25 | 37 |
ParamNBR: 2 | 6 | 9 |
CalledNBR: 10 | 60 | 87 |
LOC: 43 | 195 | 273 |
LOC: Lines Of Code
Message interpretation:
OK : Nothing to say at all
* : above 75 % of value warning
Brought to you by:
