[GRASS-QA] GRASS QA: glynn | ./grass6/lib/display/window.c |1
clones ( list.c window.c )| 0 monsters | 0 warnings
grass-qa at proxy.soccerlab.polymtl.ca
Sun Apr 22 03:18:50 EDT 2007
Hello glynn,
ANALYSIS
lib/display/window.c functions
D_new_window (Begins at: 60 Ends at: 118)
Complexity: | 5 | | OK |
ParamNBR: | 5 | * | |
CalledNBR: | 12 | | OK |
LOC: | 59 | | OK |
metrics are OK
D_new_window_percent (Begins at: 120 Ends at: 150)
CalledNBR: | 5 | | OK |
LOC: | 31 | | OK |
metrics are OK
D_set_cur_wind (Begins at: 152 Ends at: 225)
Complexity: | 10 | | OK |
ParamNBR: | 1 | | OK |
CalledNBR: | 16 | | OK |
LOC: | 74 | | OK |
metrics are OK
D_get_cur_wind (Begins at: 227 Ends at: 260)
Complexity: | 3 | | OK |
CalledNBR: | 6 | | OK |
LOC: | 34 | | OK |
metrics are OK
D_show_window (Begins at: 262 Ends at: 297)
Complexity: | 2 | | OK |
CalledNBR: | 10 | | OK |
LOC: | 36 | | OK |
metrics are OK
D_get_screen_window (Begins at: 299 Ends at: 328)
ParamNBR: | 4 | | OK |
CalledNBR: | 3 | | OK |
LOC: | 30 | | OK |
metrics are OK
D_check_map_window (Begins at: 330 Ends at: 390)
Complexity: | 9 | | OK |
CalledNBR: | 14 | | OK |
LOC: | 61 | | OK |
metrics are OK
D_reset_screen_window (Begins at: 392 Ends at: 419)
CalledNBR: | 7 | | OK |
LOC: | 28 | | OK |
metrics are OK
D_timestamp (Begins at: 421 Ends at: 461)
CalledNBR: | 13 | | OK |
LOC: | 41 | | OK |
metrics are OK
D_remove_window (Begins at: 463 Ends at: 477)
Complexity: | 1 | | OK |
LOC: | 15 | | OK |
metrics are OK
D_erase_window (Begins at: 479 Ends at: 486)
LOC: | 8 | | OK |
metrics are OK
D_erase (Begins at: 488 Ends at: 505)
LOC: | 18 | | OK |
metrics are OK
D_remove_windows (Begins at: 507 Ends at: 524)
LOC: | 18 | | OK |
metrics are OK
D_full_screen (Begins at: 526 Ends at: 536)
LOC: | 11 | | OK |
metrics are OK
Clone analysis:
This file has 1 potentially cloned functions:
D_remove_window
In lib/display/window.c clones of D_remove_window are:
imagery/i.class/set_signals.c set_signals
Threshold GRASS6 key metrics values at 2007-04-22 are:
median | upper | outlier |
| quartile | limit |
Complexity (Cyclo): 5 | 25 | 37 |
ParamNBR: 2 | 6 | 9 |
CalledNBR: 10 | 60 | 87 |
LOC: 43 | 195 | 273 |
LOC: Lines Of Code
Message interpretation:
OK : Nothing to say at all
* : above 75 % of value warning
Brought to you by:
