[GRASS-QA] GRASS QA: glynn | ./grass6/lib/pngdriver/Color_table.c
|no clones | 0 monsters | 0 warnings
grass-qa at proxy.soccerlab.polymtl.ca
Sun Apr 22 21:10:17 EDT 2007
Hello glynn,
ANALYSIS
lib/pngdriver/Color_table.c functions
set_color (Begins at: 12 Ends at: 18)
Complexity: | 1 | | OK |
ParamNBR: | 4 | | OK |
CalledNBR: | 0 | | OK |
LOC: | 7 | | OK |
metrics are OK
init_colors_rgb (Begins at: 20 Ends at: 38)
Complexity: | 2 | | OK |
ParamNBR: | 1 | | OK |
CalledNBR: | 1 | | OK |
LOC: | 19 | | OK |
metrics are OK
init_colors_indexed (Begins at: 40 Ends at: 81)
Complexity: | 3 | | OK |
CalledNBR: | 3 | | OK |
LOC: | 42 | | OK |
metrics are OK
init_color_table (Begins at: 83 Ends at: 89)
CalledNBR: | 2 | | OK |
LOC: | 7 | | OK |
metrics are OK
get_color_rgb (Begins at: 91 Ends at: 94)
LOC: | 4 | | OK |
metrics are OK
get_color_indexed (Begins at: 96 Ends at: 102)
LOC: | 7 | | OK |
metrics are OK
get_pixel_rgb (Begins at: 104 Ends at: 110)
ParamNBR: | 5 | * | |
LOC: | 7 | | OK |
metrics are OK
get_pixel_indexed (Begins at: 112 Ends at: 118)
LOC: | 7 | | OK |
metrics are OK
get_pixel (Begins at: 121 Ends at: 127)
LOC: | 7 | | OK |
metrics are OK
get_color (Begins at: 129 Ends at: 134)
LOC: | 6 | | OK |
metrics are OK
PNG_lookup_color (Begins at: 136 Ends at: 139)
ParamNBR: | 3 | | OK |
LOC: | 4 | | OK |
metrics are OK
Clone analysis:
This file does not contain cloned functions
Threshold GRASS6 key metrics values at 2007-04-22 are:
median | upper | outlier |
| quartile | limit |
Complexity (Cyclo): 5 | 25 | 37 |
ParamNBR: 2 | 6 | 9 |
CalledNBR: 10 | 60 | 87 |
LOC: 43 | 195 | 273 |
LOC: Lines Of Code
Message interpretation:
OK : Nothing to say at all
* : above 75 % of value warning
Brought to you by:
