[GRASS-QA] GRASS QA: martinl | ./grass6/vector/v.to.db/report.c |no clones | 0 monsters | 1 warnings
Mon Apr 23 07:43:28 EDT 2007
Hello martinl,
ANALYSIS
vector/v.to.db/report.c functions
report (Begins at: 6 Ends at: 144)
Complexity:   |      29 |    ** | Warning |
ParamNBR:     |       1 |       |      OK |
CalledNBR:    |      34 |       |      OK |
LOC:          |     139 |     * |         |
at least 1 values are close to an outlier please consider revising code
print_stat (Begins at: 147 Ends at: 159)
Complexity:   |       2 |       |      OK |
CalledNBR:    |      14 |       |      OK |
LOC:          |      13 |       |      OK |
metrics are OK
Clone analysis:
Threshold GRASS6 key metrics values at 2007-04-23 are:
                           | quartile  | limit   |
ParamNBR:                2 |         6 |       9 |
CalledNBR:              10 |        60 |      87 |
LOC:                    43 |       195 |     273 |
 LOC: Lines Of Code
Message interpretation:
 OK : Nothing to say at all
Brought to you by:
