[GRASS-QA] GRASS QA: scott | ./grass6/display/d.what.rast/main.c |no clones | 0 monsters | 0 warnings
Mon Apr 23 12:31:17 EDT 2007
Hello scott,
ANALYSIS
display/d.what.rast/main.c functions
main (Begins at: 29 Ends at: 169)
Complexity:   |      19 |     * |         |
CalledNBR:    |      58 |     * |         |
LOC:          |     141 |     * |         |
metrics are OK
Clone analysis:
Threshold GRASS6 key metrics values at 2007-04-23 are:
                           | quartile  | limit   |
ParamNBR:                2 |         6 |       9 |
CalledNBR:              10 |        60 |      87 |
LOC:                    43 |       195 |     273 |
 LOC: Lines Of Code
Message interpretation:
 OK : Nothing to say at all
Brought to you by:
