[GRASS-QA] GRASS QA: glynn | ./grass6/lib/pngdriver/read_bmp.c |no clones | 0 monsters | 0 warnings
Mon Apr 23 16:08:47 EDT 2007
Hello glynn,
ANALYSIS
lib/pngdriver/read_bmp.c functions
get_2 (Begins at: 9 Ends at: 15)
Complexity:   |       1 |       |      OK |
ParamNBR:     |       1 |       |      OK |
CalledNBR:    |       0 |       |      OK |
LOC:          |       7 |       |      OK |
metrics are OK
get_4 (Begins at: 17 Ends at: 23)
LOC:          |       7 |       |      OK |
metrics are OK
read_bmp_header (Begins at: 25 Ends at: 63)
Complexity:   |      11 |       |      OK |
CalledNBR:    |      14 |       |      OK |
LOC:          |      39 |       |      OK |
metrics are OK
read_bmp (Begins at: 65 Ends at: 100)
Complexity:   |       5 |       |      OK |
CalledNBR:    |      13 |       |      OK |
LOC:          |      36 |       |      OK |
metrics are OK
Clone analysis:
Threshold GRASS6 key metrics values at 2007-04-23 are:
                           | quartile  | limit   |
ParamNBR:                2 |         6 |       9 |
CalledNBR:              10 |        60 |      87 |
LOC:                    43 |       195 |     273 |
 LOC: Lines Of Code
Message interpretation:
 OK : Nothing to say at all
Brought to you by:
