[GRASS-QA] GRASS QA: scott | ./grass6/lib/db/dbmi_base/xdr.c |no clones | 0 monsters | 0 warnings
Mon Apr 23 18:11:17 EDT 2007
Hello scott,
ANALYSIS
lib/db/dbmi_base/xdr.c functions
db__set_protocol_fds (Begins at: 20 Ends at: 24)
Complexity:   |       1 |       |      OK |
CalledNBR:    |       0 |       |      OK |
LOC:          |       5 |       |      OK |
metrics are OK
xdr_begin_send (Begins at: 27 Ends at: 32)
ParamNBR:     |       1 |       |      OK |
CalledNBR:    |       1 |       |      OK |
LOC:          |       6 |       |      OK |
metrics are OK
xdr_begin_recv (Begins at: 35 Ends at: 40)
LOC:          |       6 |       |      OK |
metrics are OK
xdr_end_send (Begins at: 43 Ends at: 49)
Complexity:   |       3 |       |      OK |
CalledNBR:    |       2 |       |      OK |
LOC:          |       7 |       |      OK |
metrics are OK
xdr_end_recv (Begins at: 52 Ends at: 57)
LOC:          |       6 |       |      OK |
metrics are OK
Clone analysis:
Threshold GRASS6 key metrics values at 2007-04-23 are:
                           | quartile  | limit   |
ParamNBR:                2 |         6 |       9 |
CalledNBR:              10 |        60 |      87 |
LOC:                    43 |       195 |     273 |
 LOC: Lines Of Code
Message interpretation:
 OK : Nothing to say at all
Brought to you by:
