[GRASS-QA] GRASS QA: hamish | ./grass6/lib/symbol/stroke.c |no clones | 0 monsters | 0 warnings
Thu Apr 26 09:55:29 EDT 2007
Hello hamish,
ANALYSIS
lib/symbol/stroke.c functions
add_coor (Begins at: 24 Ends at: 35)
Complexity:   |       2 |       |      OK |
ParamNBR:     |       3 |       |      OK |
CalledNBR:    |       3 |       |      OK |
LOC:          |      12 |       |      OK |
metrics are OK
stroke_chain (Begins at: 43 Ends at: 134)
Complexity:   |      20 |     * |         |
ParamNBR:     |       4 |       |      OK |
CalledNBR:    |      15 |       |      OK |
LOC:          |      92 |       |      OK |
metrics are OK
S_stroke (Begins at: 142 Ends at: 168)
Complexity:   |       4 |       |      OK |
CalledNBR:    |       4 |       |      OK |
LOC:          |      27 |       |      OK |
metrics are OK
Clone analysis:
Threshold GRASS6 key metrics values at 2007-04-26 are:
                           | quartile  | limit   |
ParamNBR:                2 |         6 |       9 |
CalledNBR:              10 |        60 |      87 |
LOC:                    43 |       195 |     273 |
 LOC: Lines Of Code
Message interpretation:
 OK : Nothing to say at all
Brought to you by:
