[GRASS-QA] GRASS QA: scott | ./grass6/lib/display/draw.c |no clones
| 0 monsters | 1 warnings
grass-qa at proxy.soccerlab.polymtl.ca
Thu Apr 26 14:38:12 EDT 2007
Hello scott,
ANALYSIS
lib/display/draw.c functions
D_set_clip_window (Begins at: 76 Ends at: 111)
Complexity: | 3 | | OK |
ParamNBR: | 4 | | OK |
CalledNBR: | 2 | | OK |
LOC: | 36 | | OK |
metrics are OK
D_set_clip_window_to_map_window (Begins at: 113 Ends at: 134)
Complexity: | 1 | | OK |
ParamNBR: | 1 | | OK |
CalledNBR: | 5 | | OK |
LOC: | 22 | | OK |
metrics are OK
D_set_clip_window_to_screen_window (Begins at: 136 Ends at: 158)
LOC: | 23 | | OK |
metrics are OK
D_cont_abs (Begins at: 160 Ends at: 195)
ParamNBR: | 2 | | OK |
CalledNBR: | 4 | | OK |
LOC: | 36 | | OK |
metrics are OK
D_cont_rel (Begins at: 197 Ends at: 212)
CalledNBR: | 1 | | OK |
LOC: | 16 | | OK |
metrics are OK
D_move_abs (Begins at: 214 Ends at: 232)
CalledNBR: | 0 | | OK |
LOC: | 19 | | OK |
metrics are OK
D_move_rel (Begins at: 234 Ends at: 248)
LOC: | 15 | | OK |
metrics are OK
clip (Begins at: 250 Ends at: 389)
Complexity: | 27 | ** | Warning |
CalledNBR: | 8 | | OK |
LOC: | 140 | * | |
at least 1 values are close to an outlier please consider revising code
line_eq (Begins at: 391 Ends at: 399)
Complexity: | 2 | | OK |
ParamNBR: | 6 | * | |
LOC: | 9 | | OK |
metrics are OK
Clone analysis:
This file does not contain cloned functions
Threshold GRASS6 key metrics values at 2007-04-26 are:
median | upper | outlier |
| quartile | limit |
Complexity (Cyclo): 5 | 25 | 37 |
ParamNBR: 2 | 6 | 9 |
CalledNBR: 10 | 60 | 87 |
LOC: 43 | 195 | 273 |
LOC: Lines Of Code
Message interpretation:
OK : Nothing to say at all
* : above 75 % of value warning
Brought to you by:
