[GRASS-QA] GRASS QA: scott | ./grass6/lib/driver/init.c |no clones | 0 monsters | 0 warnings
Fri Apr 27 16:20:39 EDT 2007
Hello scott,
ANALYSIS
lib/driver/init.c functions
LIB_init (Begins at: 45 Ends at: 86)
Complexity:   |       5 |       |      OK |
ParamNBR:     |       3 |       |      OK |
CalledNBR:    |      11 |       |      OK |
LOC:          |      42 |       |      OK |
metrics are OK
Clone analysis:
Threshold GRASS6 key metrics values at 2007-04-27 are:
                           | quartile  | limit   |
ParamNBR:                2 |         6 |       9 |
CalledNBR:              10 |        60 |      87 |
LOC:                    43 |       195 |     273 |
 LOC: Lines Of Code
Message interpretation:
 OK : Nothing to say at all
Brought to you by:
