[GRASS-QA] GRASS QA: markus | ./grass6/raster/simwe/simlib/input.c
|no clones | 3 monsters | 1 warnings
grass-qa at proxy.soccerlab.polymtl.ca
Mon Apr 30 03:13:25 EDT 2007
Hello markus,
ANALYSIS
raster/simwe/simlib/input.c functions
input_data (Begins at: 25 Ends at: 347)
Complexity: | 80 | *** | MONSTER |
ParamNBR: | 0 | | OK |
CalledNBR: | 125 | *** | MONSTER |
LOC: | 323 | *** | MONSTER |
3 metric are OUT OF RANGE!
grad_check (Begins at: 351 Ends at: 569)
Complexity: | 25 | * | |
CalledNBR: | 34 | | OK |
LOC: | 219 | ** | Warning |
at least 1 values are close to an outlier please consider revising code
amax1 (Begins at: 572 Ends at: 583)
Complexity: | 2 | | OK |
ParamNBR: | 2 | | OK |
CalledNBR: | 0 | | OK |
LOC: | 12 | | OK |
metrics are OK
amin1 (Begins at: 586 Ends at: 597)
LOC: | 12 | | OK |
metrics are OK
min (Begins at: 600 Ends at: 613)
LOC: | 14 | | OK |
metrics are OK
max (Begins at: 615 Ends at: 626)
LOC: | 12 | | OK |
metrics are OK
Clone analysis:
This file does not contain cloned functions
Threshold GRASS6 key metrics values at 2007-04-30 are:
median | upper | outlier |
| quartile | limit |
Complexity (Cyclo): 5 | 25 | 37 |
ParamNBR: 2 | 6 | 9 |
CalledNBR: 10 | 60 | 87 |
LOC: 43 | 195 | 273 |
LOC: Lines Of Code
Message interpretation:
OK : Nothing to say at all
* : above 75 % of value warning
Brought to you by:
