[GRASS-QA] GRASS QA: soeren | ./grass6/lib/gpde/N_upwind.c |no
clones | 0 monsters | 0 warnings
grass-qa at proxy.soccerlab.polymtl.ca
Mon Apr 30 08:18:44 EDT 2007
Hello soeren,
ANALYSIS
lib/gpde/N_upwind.c functions
N_full_upwinding (Begins at: 33 Ends at: 62)
Complexity: | 5 | | OK |
ParamNBR: | 3 | | OK |
CalledNBR: | 0 | | OK |
LOC: | 30 | | OK |
metrics are OK
N_exp_upwinding (Begins at: 64 Ends at: 78)
Complexity: | 3 | | OK |
CalledNBR: | 1 | | OK |
LOC: | 15 | | OK |
metrics are OK
Clone analysis:
This file does not contain cloned functions
Threshold GRASS6 key metrics values at 2007-04-30 are:
median | upper | outlier |
| quartile | limit |
Complexity (Cyclo): 5 | 25 | 37 |
ParamNBR: 2 | 6 | 9 |
CalledNBR: 10 | 60 | 87 |
LOC: 43 | 195 | 273 |
LOC: Lines Of Code
Message interpretation:
OK : Nothing to say at all
* : above 75 % of value warning
Brought to you by:
