[GRASS-QA] GRASS QA: carlos | ./grass6/display/d.rast.edit/cell.c
|1 clones ( cell.c )| 0 monsters | 0 warnings
grass-qa at proxy.soccerlab.polymtl.ca
Fri Aug 3 12:08:37 EDT 2007
Hello carlos,
ANALYSIS
display/d.rast.edit/cell.c functions
Dcell (Begins at: 25 Ends at: 71)
Complexity: | 6 | | OK |
ParamNBR: | 3 | | OK |
CalledNBR: | 22 | | OK |
LOC: | 47 | | OK |
metrics are OK
cell_draw (Begins at: 74 Ends at: 111)
Complexity: | 3 | | OK |
ParamNBR: | 4 | | OK |
CalledNBR: | 14 | | OK |
LOC: | 38 | | OK |
metrics are OK
Clone analysis:
This file has 1 potentially cloned functions:
cell_draw
In display/d.rast.edit/cell.c clones of cell_draw are:
lib/D/Dcell.c cell_draw
Threshold GRASS6 key metrics values at 2007-08-03 are:
median | upper | outlier |
| quartile | limit |
Complexity (Cyclo): 5 | 25 | 37 |
ParamNBR: 2 | 6 | 9 |
CalledNBR: 10 | 60 | 88 |
LOC: 43 | 195 | 272 |
LOC: Lines Of Code
Message interpretation:
OK : Nothing to say at all
* : above 75 % of value warning
Brought to you by:
